Current AWS elastic load balancer instances
You might want to retrieve basic information about your elastic load balancer (ELB) instances when doing the following:
Your organization has a large number of ELB instances currently deployed to AWS. You want to be able to quickly take an inventory of all of them, as well as their configured fully qualified domain names (FQDN), to better manage your cloud infrastructure.
  1. Run the following search:
source="*_load_balancers" sourcetype="aws:description"
|eval name=if(isnull(name),LoadBalancerName,name), vpc_id=if(isnull(vpc_id),VpcId,vpc_id), dns_name=if(isnull(dns_name),DNSName,dns_name), id=((((name . "#") . account_id) . "#") . region)
|dedup id sortby - created_time
|table account_id created_time region name dns_name vpc_id
Search only your load balancers and filter by description data.
If the name field is null, set it to the value in LoadBalancer, otherwise set name to name. Repeat for the vpc_id and dns_name fields.
Create the id field as a concatenation of  name, account_id, and region with the “#” in between.
Remove duplicate instances by ID and sort the remaining results with the most recent instances first.
Sample results for this search are shown in the table below. Created_time is an interesting field to sort on because you could determine how long the ELB has been in service. The table also shows information on network dns, virtual private cloud id, location, and account owner. Other fields that are available but not shown below include subnets, ports, protocols, listener, and instance state and  ssl_certificate_id. Depending on the information you are trying to track, these might be of interest to add to the table or track separately.
63605715280
2015-11-11T06:00:57.730Z
ap-southeast-1
TestELB3
TestELB2-1018970143.ap-southeast-1.elb.amazonaws.com
vpc-d2d110ba
63605715280
ap-southeast-1
TATestELB6
vpc-d2d110ba
63605715280
2015-12-09T09:01:33.070Z
ap-southeast-1
SaaSQATestELB3
SaaSQATestELB3-792083005.ap-southeast-1.elb.amazonaws.com
vpc-d2d110ba
63605715280
2015-12-11T10:05:10.170Z
ap-southeast-1
TAtestelb3
saastestelb-1720685174.ap-southeast-1.elb.amazonaws.com
vpc-d2d110ba
63605715280
2015-11-12T14:54:21.170Z
ap-southeast-1
TATestELB5
TestELB1-2109315026.ap-southeast-1.elb.amazonaws.com
vpc-d2d110ba
