Inventory of devices reporting network data
You need broad network visibility to set the stage for availability monitoring and alerting should devices stop sending data. You know that the best place to start is obtaining an inventory of every device on the network.
To collect SNMP traps in Splunk, you will need to run an snmptrapd server on a Linux or Windows machine to collect traps and write them to a file. After they are written to disk, you can configure the Universal Forwarder to read those files and forward them to Splunk; this configuration is outlined in our documentation
Procedure
  1. Ensure you have configured Splunk Connect for Syslog.
  2. If you are switching to Splunk software from another vendor, front SC4S with the same IP address that your previous software used to collect syslog traffic. Doing so helps prevent the need to reconfigure all network devices and firewall rules that would be necessary to allow syslog traffic to flow to a new syslog receiver.
  3. Run the following search. You can optimize it by specifying an index and adjusting the time range.
index IN (*) sourcetype IN (*) sc4s_vendor_product=*
| stats count BY host, sourcetype, sc4s_vendor_product
index IN (*) sourcetype IN (*) sc4s_vendor_product=* Search all data coming into the Splunk Connect for Syslog app.
| stats count BY host, sourcetype, sc4s_vendor_product  Display a count of the source types and related products for each host on your network.
To further restrict your search, limit the search to include only the source types associated with your networking devices. Use the results to determine what needs to be investigated further.
You might be interested in other processes associated with the Recovering lost visibility of IT infrastructure use case.
