Top ten highest network utilization queries
You might want to know what queries to your database transfer the most data when doing the following:
Queries that result in large transfers of data into or out of the database may be a sign of an inefficient design and can place a strain on the networking infrastructure between the client and the database. You want to create a list of the top ten so that you can work with the owners to refactor such queries.
  1. Run the following search:
|stats count sum(bytes) AS total_bytes BY query
|eval avg_bytes_per_execution = round(total_bytes/count, 2)
|sort - total_bytes
|head 10
Count each query, as well as the total bytes used by that query.
Return the average bytes per query execution (rounded to two decimal points) by dividing the total bytes by the number of queries.
|sort - total_bytes
Sort the results according to total bytes with the largest value first.
|head 10
Display the top 10 results in a table.
The output from the query includes the text for each of the SQL statements, the count of the number of times the statement appears, the total bytes in the result set, and the average number of bytes for each statement. The following table is a sample result.
query count total_bytes avg_bytes_per_execution
SELECT * FROM hr_employee_info
1700
16994436
9996.73
SELECT password FROM SYS.USER$ WHERE name='SYS'
887
678370
764.79
SELECT * FROM customers WHERE customer_uid=3bf48b89-77b0-4cc2-ab5b-afbe08dc1e96
22
52722
2396.45
SELECT * FROM customers WHERE customer_uid=b56a5c74-87a3-4593-9eb5-2d2b1c38a0d8
22
45145
2052.05
This sample output is telling in several ways. First, large result sets, such as the SELECT * FROM result in the first row, should not be expected. If they occur often, they might be indicative of inefficient SQL. Owners should be notified when their queries are in the top ten largest data transfer queries. When possible, and if appropriate, owners should refactor the queries to transfer less data. They may also indicate a security concern if the data is of a sensitive nature, such as human resources data and passwords. The example above shows both.
Potential next steps are to correlate this database activity with applications and users to put it into a business context. If user or application id is in the stream, you could add it to the split by clause of the stats command like this:
| stats count sum(bytes) AS total_bytes BY query user
Lastly, you could vary the sort by fields to look at count or avg_bytes_per_execution and use the results to determine the most beneficial troubleshooting steps to take.
