Duplex mismatch in Cisco IOS devices
You might need to identify duplex mismatches on your Cisco devices when doing the following:
The Cisco IOS system message logging process uses the syslog protocol to send important messages to remote logging services, such as Splunk. The required add-on expects the data stream to be assigned the syslog sourcetype by the input configuration and will rename it to cisco:ios in the transformation configuration. For details on how the transformation is implemented, see the props.conf and transforms.conf in the add-on and the Splunk documentation. For more information on syslog and Splunk, see the (SYSLOG) Syslog Data Collection section of the Splunk Validated Architectures white paper.
Duplex mismatches occur when two physically connected devices have been configured in different duplex modes. A Cisco IOS device can detect a duplex mismatch between it and another device and emits a message when found. You want to identify duplex mismatches and investigate their cause.
  1. Run the following search:
sourcetype=cisco:ios
mnemonic="DUPLEX_MISMATCH"
| rename dvc AS local_host cdp_local_duplex AS local_setting cdp_neighbor AS dest_host cdp_remote_duplex AS dest_setting
| table local_host local_setting dest_host dest_setting dest_interface
Search only Cisco IOS data.
Search for duplex mismatch messages.
Rename the fields as shown for better readability.
Display the results in a table with columns in the order shown. Use a table to
The following sample result from the search shows hosts that are connected but with mismatched duplex settings. Use this table to identify which hosts and ports need to be corrected.
10.10.20.30
not half duplex
hel-c-001-rtr-1
half duplex
Port1
sto-c-001-rtr-1
not half duplex
hel-c-001-rtr-1
half duplex
Port1
