Duplicate IP addresses in Cisco IOS devices
You might need to look for duplicate IP addresses on your Cisco devices when doing the following:
The Cisco IOS system message logging process uses the syslog protocol to send important messages to remote logging services, such as Splunk. The required add-on expects the data stream to be assigned the syslog sourcetype by the input configuration and will rename it to cisco:ios in the transformation configuration. For details on how the transformation is implemented, see the props.conf and transforms.conf in the add-on and the Splunk documentation. For more information on syslog and Splunk, see the (SYSLOG) Syslog Data Collection section of the Splunk Validated Architectures white paper.
IP addresses uniquely identify each and every network device and should never be duplicated. However, networking misconfigurations and circumstances sometimes cause IP addresses to be duplicated across devices, which then leads to unpredictable system behavior. You want to use a Splunk search with your Cisco IOS device logs to detect the presence of duplicate IP addresses and emit a message when found.
  1. Run the following search:
sourcetype=cisco:ios mnemonic="DUPADDR"
| stats count values(src_mac) AS “On MAC_ADDR” values(src_interface) AS interfaces BY host src_ip
| rename src_ip AS Duplicat_Address
Search only Cisco IOS data.
mnemonic="DUPADDR"
Filter for duplicate address error messages.
| stats count values(src_mac) as "On MACADDR" values(src_interface) as interfaces by host src_ip
Count the number of duplicate address error messages and show with address is the duplicate found on which MAC address.
| rename src_ip AS Duplicate_Address
Rename the field as shown for better readability.
The following is a sample result from the search and shows a duplicate IP address, the MAC addresses that the IP address is assigned to, and the host and interfaces involved. The host refers to the Cisco device that reported the error.
host Duplicate_Address count On MACADDR interfaces
10.10.20.30
192.168.211.1
83
00:15:f9:87:94:1a 31:CE:67:20:96:A5
FastEthernet0/0
