Port flapping on Cisco IOS devices
Port flapping is a situation in which a physical interface on the switch continually goes up and down, three or more times a second for at least 10 seconds. You might need to identify when port flapping happens on your Cisco devices when doing the following:
The Cisco IOS system message logging process uses the syslog protocol to send important messages to remote logging services, such as Splunk. The required add-on expects the data stream to be assigned the syslog sourcetype by the input configuration and will rename it to cisco:ios in the transformation configuration. For details on how the transformation is implemented, see the props.conf and transforms.conf in the add-on and the Splunk documentation. For more information on syslog and Splunk, see the (SYSLOG) Syslog Data Collection section of the Splunk Validated Architectures white paper.
Common causes for port flapping are bad, unsupported, or non-standard cable or other link synchronization issues. The cause for port flapping can be intermittent or permanent. You need a search to identify when it happens on your network so you can investigate and resolve the problem.
  1. Run the following search:
eventtype=cisco_ios-port_down OR eventtype=cisco_ios-port_up product=IOS
| eval port_state=if(vendor_action="up",1,0)
| stats sparkline(sum(port_state),15m) AS trend count, latest(vendor_action) AS current_port_status BY host,src_interface
| eventstats sum(count) AS host_total BY host
| sort -host_total -count
| fields -host_total
| table host,src_interface,trend,current_port_status,count
eventtype="cisco_ios-port_down" OR eventtype="cisco_ios-port_up"
Search for port up and port down events in all Cisco IOS data. Eventtypes are supplied by the TA
product=IOS
Further constrain results to where product is IOS
Evaluate the port state as 1 if the status is "up", and 0 otherwise. These numeric values are needed later to calculate the trend with the sparline.
Create a trendline of port statistics over the last 15 minutes.
Calculate a running total number of port flaps for each host.
Sort the results by host total and secondarily by message count, with the highest values first.
| fields - host_total
Remove the host total field from the results.
The following sample result from the search shows the host, source interface, current port status, and the count for the host. The sparkline is not shown below but would be rendered by Splunk.
host src_interface current_port_status count
cph-c-001-rtr-1
Ethernet1/0/46
up
7
hel-c-001-rtr-1
Ethernet1/0/46
up
5
osl-e-310-swi-1
Ethernet1/0/46
up
5
