*Nix CPU utilization nearing capacity
You might want to detect when CPU utilization is nearing capacity when doing the following:
Excessive CPU utilization on a host, particularly abnormal or prolonged, is a sign of potential issues with the critical applications running on the host. You want to detect when an application is starved for CPU resources so you can prevent performance degradations or application instability.
Option 1
  1. Ensure that you have installed Install the Splunk Add-on for Unix and Linux on your Splunk search head, indexer, and the Splunk universal forwarders on the monitored systems. Click here for an example inputs.conf file that can be deployed to the universal forwarder on the *nix host to collect Memory utilization data and store the results into a metrics index.
  2. In Splunk Enterprise or Splunk Cloud Platform, run the following search:
| mstats min(cpu_metric.pctIdle) AS Idle WHERE index="<name of *nix metrics index>" AND host="<name of host to check>" span=1m BY host
| eval cpu_utilization=(100 - Idle)
| timechart max(cpu_utilization) AS cpu_utilization BY host
| mstats min(cpu_metric.pctIdle) AS Idle WHERE index="<name of *nix metrics index>" AND host="<name of host to check>" span=1m BY host Search metrics index(s) where CPU utilization data is being collected and filter down to the desired host(s).
| eval cpu_utilization=(100 - Idle) Convert percent idle to percent utilized for readability.
| timechart max(cpu_utilization) AS cpu_utilization BY host Plot CPU utilization over time.
Set up an alert based on this search so you can proactively manage potential stability issues. To alert when a CPU utilization is nearing max capacity, you can configure one of the following two recommendations:
  • Use the SPL from this procedure to configure a Core Splunk alert.
  • Configure the Average CPU Usage vital metric for the Unix/Linux entity type in IT Essentials Work to alert when the CPU Utilization percentage is at or near 100.
Option 2
  1. Ensure that you have the Splunk OTEL Collector installed on the host you want to monitor.
  2. In Splunk Infrastructure Monitoring, use the following SignalFlow to search the cpu.utilization streaming metric and filter down to the hosts and processes you want to check.
    A = data('cpu.utilization', filter=filter('host.name', '<name of host to check>')).publish(label='A')
To alert when CPU utilization is nearing max capacity for the selected host(s) and process(es), use the SignalFlow from this procedure to configure a detector with an alert condition of "Static Threshold" and alert settings of:
  • Alert when: Above
  • Threshold: 95
  • Trigger sensitivity: Duration
  • Duration: 5m
