Package installations and upgrades on a *nix server
You might want to monitor package installations and upgrades on a *nix server when doing the following:
System patches, software upgrades, and software installations are risky processes in a production environment. They can lead to an outage or incident if the software installation introduces compatibility issues with critical processes and applications running on the host. You want a search that will show you recent software changes on a host, so you can more easily identify what changed and when while investigating an incident.
Run the following search:
((tag=update) OR (yum ("Updated:" OR "Installed:")) OR (sourcetype=dnf ("Installed:" OR "Upgraded:"))) (NOT Downloading:) host=*
|rex "(?s)(Upgraded|Updated):(?<pkgs_updated>.*?(?=Installed:|\Z))"
|rex "(?s)Installed:(?<pkgs_installed>.*)"
|rex mode=sed field=pkgs_updated "s/\s+/ /g"
|rex mode=sed field=pkgs_installed "s/\s+/ /g"
|eval pkgs_updated=split(pkgs_updated, " "), pkgs_installed=split(pkgs_installed, " ")
|table _time host pkgs* _raw
Return all software installations and upgrades in your environment.
host=*
Search on all hosts.
Capture everything between Upgraded: OR Updated: and =Installed or the end of the string.
Capture everything after Installed:.
Replace any white space with a single space in the string pointed to by pkgs_updated.
Replace any white space with a single space in the string pointed to by pkgs_installed.
Split the listed field by the single space added in the rex commands.
Sample results for this search are shown in the table below. It shows the time of the update or upgrade, the affected host, and the name of the package that has either installed or been updated.
_time host pkgs_installed pkgs_updated
2020-09-03T12:37:16.000-0700
ip-172-31-64-114
httpd-tools-2.4.43-1.amzn2.x86_64
2020-09-03T12:37:15.000-0700
ip-172-31-64-114
apr-util-bdb-1.6.1-5.amzn2.0.2.x86_64
ip-172-31-64-114
apr-1.6.3-5.amzn2.0.2.x86_64
2020-09-03T08:50:02.000-0700
ip-172-31-27-100.us-west-1.compute.internal
grub2-tools-efi-1:2.02-87.el8_2.x86_64
kernel-4.18.0-193.14.3.el8_2.x86_64
kernel-core-4.18.0-193.14.3.el8_2.x86_64
kernel-modules-4.18.0-193.14.3.el8_2.x86_64
linux-firmware-20191202-97.gite8a0f4c9.el8.noarch
NetworkManager-1:1.22.8-5.el8_2.x86_64
NetworkManager-libnm-1:1.22.8-5.el8_2.x86_64
NetworkManager-team-1:1.22.8-5.el8_2.x86_64
NetworkManager-tui-1:1.22.8-5.el8_2.x86_64
bind-export-libs-32:9.11.13-5.el8_2.x86_64
ca-certificates-2020.2.41-80.0.el8_2.noarch
cloud-init-19.4-1.el8.7.noarch
coreutils-8.30-7.el8_2.1.x86_64
coreutils-common-8.30-7.el8_2.1.x86_64
dbus-1:1.12.8-10.el8_2.x86_64
dbus-common-1:1.12.8-10.el8_2.noarch
dbus-daemon-1:1.12.8-10.el8_2.x86_64
dbus-libs-1:1.12.8-10.el8_2.x86_64
dbus-tools-1:1.12.8-10.el8_2.x86_64
dnf-4.2.17-7.el8_2.noarch
dnf-data-4.2.17-7.el8_2
