Processes running after *nix patching event
You might want to count the number of running processes before and after patching when doing the following:
System patching is a risky process in a production environment. Based on the method by which a critical process was originally started or configured, it might not survive the patching and reboot event. You want a search that will let you determine the number of running processes before and after a patching event.
Run the following search:
source=ps earliest=-15m@m latest=now
|eval dataset="last 15m"
|append
[|search index=<index name> source=ps earliest=-75m@m latest=-60m@m
|eval dataset="1h ago"]
|search user!=root
|stats dc(dataset) AS dc_dataset values(dataset) AS values_dataset BY COMMAND host
|eval no_longer_running_process = if(dc_dataset=1 AND values_dataset="1h ago", COMMAND, null())
|eval newly_running_process = if(dc_dataset=1 AND values_dataset="last 15m", COMMAND, null())
|stats values(*_running_process) AS *_running_process BY host
source=ps
Search process information.
Search back for 15 minutes from now.
Set the field named dataset to the quoted string.
|append
Search for events that occurred an hour ago and look back for 75 minutes. Append the results to the primary search.
|search user!=root
Include results not run by root.
Get a distinct count of the dataset by filesystem and put the contents of the dataset into values.
Create the no_longer_running_process field for a process distinct count of “1” when the count only existed 1 hour ago.
Create the newly_running_process field for a directory process count of “1” when the count only exists within the last 15 minutes.
Create a list of process statuses by host.
Sample results for this search are shown in the table below. A process shown in the no_longer_running column might indicate that something went wrong due to the patch. In the sample below, sshd is not running, so the patch may have broken the configuration of sshd and should be investigated.
This search, alongside monitoring package installations and upgrades on a *nix server, could be used to see what was upgraded on a host that shows a process that is no longer running. Putting these events side-by-side on a dashboard can save time. You can also create a correlation between the two searches and use an alert when the condition is met.
host newly_running_process no_longer_running_process still_running_process
ip-172-31-64-114.ec2.internal
httpd
Chronyd
dbus-daemon
lsmd
pickup
qmgr
rpcbind
sshd:
ip-172-31-71-164.ec2.internal
sshd:
chronyd
dbus-daemon
lsmd
Pickup
Qmgr
 rpcbind
ip-172-31-79-80.ec2.internal
chronyd
dbus-daemon
 lsmd
pickup
qmgr
rpcbind
sshd:
