ESXi host version identification
You might need to report on the versions of VMWare ESXi actively running within your virtualization environment when doing the following:
A report of the versions of VMWare ESXi actively running within your virtualization environment can help you identify version inconsistencies or older versions in need of upgrade.
  3. Run the following search:
| mcatalog values(os_version) AS esxiversion WHERE index=vmware-perf-metrics AND entity_type=vsphere.esxihost BY name
| dedup name sortby - _time
| stats count BY esxiversion
Search VMWare metric indexes for ESXi version values by ESXi host.
Remove duplicate ESXi hosts from the results.
| stats count BY esxiversionmoid="*"
Provide a count of the results, sorted by version ID.
Upgrade versions as needed.
