Recently triggered vSphere alarms
You might need to see all recently triggered vSphere alarms when doing the following:
VMware vSphere lets you author alerting rules to identify various conditions that occur in your VMware environment. Some alerts indicate problems while others are informational. You want a search that allows you to easily see all alarms so that you can review them and investigate further if necessary.
  3. Run the following search:
index="vmware-taskevent" sourcetype="vmware_inframon:events"
| spath alarm
| search alarm=*
| eval From=if(isnull('from'),"N/A",'from'), To=if(isnull('to'),"N/A",'to')
| stats count BY host, entity.entity.type, entity.name, From, To, fullFormattedMessage, _time
| rename host AS vCenter entity.entity.type AS "Entity Type" entity.name AS "Entity Name" fullFormattedMessage AS "Message"
| fields - count
index="vmware-taskevent" sourcetype="vmware_inframon:events"  Search event indexes for VMWare events.
| spath alarm
| search alarm=*
Search for events with alarms.
| eval From=if(isnull('from'),"N/A",'from'), To=if(isnull('to'),"N/A",'to')  Validate that data is present.
| stats count BY host, entity.entity.type, entity.name, From, To, fullFormattedMessage, _time  Display the alarm related information.
| rename host AS vCenter entity.entity.type AS "Entity Type" entity.name AS "Entity Name" fullFormattedMessage AS "Message"  Rename the fields as shown for better readability.
| fields - count Remove the count field from the results.
The results shows the time each alarm was triggered, the host they were triggered on, the host’s previous status and current status after the alarm, and the alarm’s message. Depending on the types of rules you author and activate, it might be helpful to correlate VMware alerts with other operational and performance metrics associated with the applications running on the virtual machine
