VMotion events for a specific virtual machine
VMotion is the process of moving a virtual machine from one ESXi host to another in an effort to balance the workload of all virtual machines as evenly and effectively as possible. You might need to track VMotion events for a specific virtual machine when doing the following:
While the VMotion process is seamless to the virtual machine operation, it can impact performance. You want to monitor virtual machines being moved from one ESXi host to another so you can be prepared for any problems caused by the process.
  3. Run the following search:
index=vmware-taskevent sourcetype="vmware_inframon:events" eventClass="VmMigratedEvent" vm.name="<VM_NAME>"
| stats count BY vm.name, eventClass, createdTime, sourceHost.name, host.name, sourceDatastore.datastore.moid, ds.datastore.moid, _time
| rename vm.name AS "VM" eventClass AS "Event Type" createdTime AS "Completed Time" host.name AS "Dest. ESXi" sourceHost.name AS "Src ESXi" sourceDatastore.datastore.moid AS "Src Datastore" ds.datastore.moid AS "Dest.Datastore"
| fields - count
Search index vmware-taskevent for Virtual Machine migrated events.
Replace <VM_NAME> with the Virtual Machine name or use * for all VMotions.
Search only virtual machines.
Rename the fields as shown for readability.
| fields - count
Remove the count field from the results.
Provide this data to application teams so they can correlate VMWare activity with application performance and behavior.
