VMware datastores with highest utilization
You might need to see your VMware datastores with the highest utilization when doing the following:
Datastores hold critical files needed for normal VMware operation. Like any other storage container, running out of space is bad. You want to see all the datastores in your environment according to the least percentage of free space remaining.
  3. Run the following search:
| mstats latest(vsphere.datastore.used_percent) WHERE (index=vmware-perf-metrics) span=1m BY name, moid, pool_name, unit, vcenter
| eval used_percent=round('latest(vsphere.datastore.used_percent)',2)
| timechart latest(used_percent) BY name
| mstats latest(vsphere.datastore.used_percent) WHERE (index=vmware-perf-metrics) span=1m BY name, moid, pool_name, unit, vcenter Search metrics index(es) where VMWare datastore metrics are collected and split by the field shown.
| eval used_percent=round('latest(vsphere.datastore.used_percent)',2) Create a new field named "used_percent" and round the value to two decimals for readability.
| timechart latest(used_percent) BY name Plot the datastore usage over time.
A potential next step is to correlate this data with asset identification data such as department, business usage, criticality, and similar attributes to further help with identification of opportunities for optimization and planning. This can be done with a lookup using the datastore ID or the url as the key into the lookup.
To alert when Average Datastore Utilization is nearing max capacity, you can configure one of the following two recommendations:
  • Use the SPL from this procedure to configure a Core Splunk alert.
  • Configure the Average Datastore Usage vital metric for the VMware Datastore entity type in IT Essentials - Work to alert when the VMware Datastore Utilization percentage is at or near 100.
