Virtual machines currently running on ESXi host
You might need to see what virtual machines are hosted in which ESXi hosts when doing the following:
Understanding which ESXi host is currently running a virtual machine is a fundamental aspect of VMware monitoring. It lets you see all virtual machines running on an ESXi host and determine if poor performance could be caused by a noisy neighbor. You want a search that will allow you to easily gather this type of inventory.
  3. Run the following search:
sourcetype=vmware:inv:hierarchy type=VirtualMachine moid="*"
|stats values(moid) AS "VM Id" BY _time changeSet.runtime.host.moid
|rename changeSet.runtime.host.moid AS "ESXi Host"
Search only VMware hierarchy inventory data and limit the search to virtual machine data.
moid="*"
Return all VMs running on a host at the point in time.
To look for a specific VM, you could change the wildcard to the name, (e.g. “vm-77”).
Group the values of the moid by the fields in the BY clause.
Rename the fields as shown for better readability.
Sample results for this search are shown in the table below. It provides a list of virtual machines (VM) running on a host at the time the data was received by Splunk. The first five entries show vm-77 moving back and forth between host-10 and host-11. The table also shows that host-10 is hosting many VMs at T13:49 and that host-26 has only three. That information could be used to consider host-26 as a candidate to balance the load by moving some VMs off of host-10.
This search would be good in a dashboard with an interactive input to select VM IDs to investigate. A second input on the same dashboard could allow for the ESXi Host to be selected, rather than defaulting to all.
_time ESXi Host VM Id
2020-11-05T13:40:19
host-10
vm-77
2020-11-05T13:41:34
host-11
vm-77
2020-11-05T13:44:22
host-10
vm-77
2020-11-05T13:45:19
host-11
vm-77
2020-11-05T13:47:490
host-10
vm-77
2020-11-05T13:49:24
host-10
vm-186
vm-187
vm-188
vm-189
vm-190
vm-192
vm-207
vm-209
vm-211
vm-216
vm-220
vm-224
vm-226
vm-231
vm-234
vm-237
vm-261
2020-11-05T13:49:24
host-26
vm-113
vm-206
vm-214
