Virtual machines with high CPU Ready summation value
"CPU Ready" indicates that a virtual machine needs access to CPU resources to continue processing, but the underlying host has no remaining CPU resources to allocate. This metric can be calculated as summation or percentage. You might need to see which virtual machines on your network have a high CPU Ready summation value when doing the following:
"CPU Ready" only occurs when the host is overprovisioned on CPU. A single virtual machine with high "CPU Ready" indicates a configuration or resource problem, and the virtual machine's performance is impacted.
  3. Run the following search:
sourcetype="vmware:perf:cpu" source="VMPerf:VirtualMachine" instance=aggregated
|stats avg(p_summation_cpu_ready_millisecond) AS avg_p_summation_cpu_ready_millisecond BY moid
|eval is_high_sumready = if(avg_p_summation_cpu_ready_millisecond > 500, "Yes", "No")
|fields moid avg_p_summation_cpu_ready_millisecond is_high_sumready
|append
    [ search index=<your index name> sourcetype="vmware:inv:hierarchy" type=VirtualMachine
    |dedup moid
    |eval esxi_moid = 'changeSet.runtime.host.moid'
    |table moid esxi_moid]
|eventstats values(esxi_moid) AS esxi_moid BY moid
|search is_high_sumready=”Yes”
|sort - avg_p_summation_cpu_ready_millisecond
|table moid esxi_moid avg_p_summation_cpu_ready_millisecond is_high_sumready
Search the VMware CPU performance source type and limit the search to VMware virtual machine performance data.
instance=aggregated
Return the most recent results for the performance metrics of all virtual machines.
Calculate the average CPU Ready summation value for each host managed object ID (MOID).
Create the is_high_sumready field for results the average is above 500ms.
Limit the results to the fields shown.
|append
|dedup moid
 fields moid esxi_moid]
Run a subsearch that returns a unique moid along with the corresponding changeSet value. Append these results to the primary (outer) search results to correlate the hierarchy data with the performance data.
Add the esxi_moid field to all virtual machine Sum Ready results.
Return all results where the average is above 500ms.
Sort results with the largest average first.
The table below shows sample results for the search. Many factors can contribute to high ready times, and referencing other relevant searches, such as ESXi hosts with high CPU Ready summation value, side-by-side on a dashboard can help you better understand the causes.
vm-199
host-20
680.6718404
Yes
vm-239
host-20
658.2372506
Yes
vm-242
host-20
633.1552106
Yes
vm-232
host-20
627.5144124
Yes
vm-213
host-20
621.9002217
Yes
