vCenter console logins
You might want to see key information about logins to vCenter when doing the following:
VMware vCenter Server is advanced server management software that provides a centralized platform for controlling your VMware vSphere environments, allowing you to automate and deliver a virtual infrastructure across the hybrid cloud. This search will help you to control access to the VMWare environment, including reviewing who has accessed the system and how frequently or infrequently they do so.
To optimize the search shown below, you should specify a time range.
  3. Run the following search:
index=vmware-taskevent sourcetype="vmware_inframon:events"
| stats count BY userName eventClass ipAddress userAgent _time
index=vmware-taskevent sourcetype="vmware_inframon:events"  Search the event index where VMware vCenter task data is collected.
| stats count BY userName eventClass ipAddress userAgent _time Display a count of results, grouped by the fields shown.
Knowing what modifications are made to the VMware environment, when they were made, and who made them can help you identify or isolate the origin of a problem or incident. To prevent accidental misconfigurations, it might be safer to revoke access for users who access VMware infrequently. This procedure might also surface accounts created for employees who are no longer with the company or no longer in the organization where VMware access is needed.
