Forwarding OCI Streaming to Splunk with Splunk OpenTelemetry Collector for Kafka
Oracle Cloud Infrastructure (OCI) Streaming speaks the Kafka protocol, which means you don't need a custom bridge to get records out of it - any Kafka-compatible consumer works. This guide shows you how to point the Splunk OpenTelemetry Collector for Kafka (SOC4Kafka) at an existing OCI Streaming stream and land those records in the Splunk platform over HTTP Event Collector (HEC), with no code in between.
Following those steps from top to bottom will bring your data to the Splunk platform. A full command-by-command reference, including OCI network and Stream Pool provisioning is available at SOC4Kafka Installation Guide — OCI Streaming to Splunk. This guide assumes that infrastructure is already provisioned and focuses on configuring the collector.
You'll pick one of two deployment forms:
  • Deployment A - Bare metal / systemd: the otelcol binary runs directly on a VM. No container runtime required. Good for a simple single-host setup.
  • Deployment B - MicroK8s: the official Helm chart runs on a single-node Kubernetes cluster. Good if you want pod-level isolation and rolling updates. The chart is distribution-agnostic - only a couple of OCI/MicroK8s-specific quirks below are specific to that combination.
How it fits together
The pipeline has three parts, all running inside a single Splunk OTel Collector process:
  • Source - OCI Streaming, consumed via its Kafka-compatible API. The collector authenticates over SASL_SSL/PLAIN on port 9092. If your Stream Pool has a private endpoint, the broker hostname resolves to a private VCN IP, so that traffic never has to leave the VCN - the VM (or cluster node) just needs network line-of-sight to it.
  • Processor - the kafka receiver hands records to a resourcedetection processor, which tags each record with host/system metadata before it's exported.
  • Sink - the splunk_hec exporter batches records and posts them to your Splunk HEC endpoint, reached outbound over the internet (or your private connectivity, if you have it).
Because SOC4Kafka doesn't implement HEC Acknowledgement, the Splunk-side prerequisite is simple but non-negotiable: HEC Indexer Acknowledgement must be OFF, or the connection will stall waiting for an ack that never comes.
From OCI
What you need Where to find it Placeholder Example value
Kafka bootstrap endpoint Streaming → Stream Pools → select pool → Kafka Connection Settings → Bootstrap Servers  <KAFKA_BOOTSTRAP> cell-1.streaming.us-ashburn-1.oci.oraclecloud.com:9092
Kafka SASL username Same page → Username (fully formed, ready to copy) <SASL_USERNAME> axhqcaz9raiv/jane.doe@
example.com/ocid1.streampool
.oc1.iad.amaaaaaaak7gxbiamhoy
xvkihphudt7wxagjaz3fqxrmyg4z
5uwvlnjq3wca
OCI auth token (SASL password) Profile → User Settings → Auth Tokens → Generate Token — copy immediately, shown once <OCI_AUTH_TOKEN>  wJ>9Qs&2poK!zL8x
Stream / topic name Streaming → Streams <TOPIC>  app-logs
Note the following:
  • SASL username format: the username is normally <tenancy-namespace>/<user>/<stream-pool-OCID>. If your tenancy uses an OCI identity domain, the username needs an extra segment: <tenancy-namespace>/<identity-domain>/<user>/<stream-pool-OCID>. Find your identity domain under Identity & Security → Domains (commonly Default). If authentication fails with SASL authentication error: Authentication failed despite a valid token, this four-part form is almost always the fix.
  • Handling special characters: the OCI auth token may contain characters like &, |, >, `, or !, there is  no need to regenerate the token if it does for the bare-metal path. Keep the single quotes shown around KAFKA_SASL_PASS and --from-literal=... below when you set it: without them, the shell interprets those characters itself and can silently truncate or empty out the value before it ever reaches the collector.
  • MicroK8s is stricter: if the token starts with a YAML-special character (#, &, *, !, >, |, @, `), the collector's env provider re-parses the substituted value as YAML — and a leading # in particular collapses the password to null, even though the secret looks correct. If your token starts with one of these, regenerate it before using the MicroK8s path.
From the Splunk platform
HEC endpoint URL Settings → Data inputs → HTTP Event Collector → host + port 8088, path /services/collector  <SPLUNK_HEC_ENDPOINT>  https://splunk.example.com:
8088/services/collector
HEC token Settings → Data inputs → HTTP Event Collector → token's Token Value  <SPLUNK_HEC_TOKEN>  b5b3c8a4-1e6d-4f2a-9c7e-2d4f6a8b0c1d
Target index Settings → Indexes  <SPLUNK_INDEX>  oci_streaming
Note the following:
  • HEC prerequisites: before installing the collector, make sure HEC is globally enabled (Global Settings → Enabled), that Indexer Acknowledgement is OFF, and that your HEC token's Allowed indexes include <SPLUNK_INDEX>
Choose a consumer group name
Pick a short, unique string for <CONSUMER_GROUP> (for example, soc4kafka-v1). This identifies your collector instance to the Kafka broker. Use a fresh name; reusing a group ID from a previous failed install can leave OCI Streaming's coordinator state poisoned for that group, causing the collector to loop indefinitely with NOT_COORDINATOR errors on startup.
Solutions
All commands run on your VM over SSH.
A.1 Install dependencies
These packages are used for connectivity testing and producing test messages - not required for the collector itself.
sudo apt-get update
sudo apt-get install -y kafkacat curl netcat-openbsd
A.2 Download the collector library
mkdir -p ~/soc4kafka && cd ~/soc4kafka
wget https://github.com/signalfx/splunk-otel-collector/releases/download/v0.155.0/otelcol_linux_amd64
chmod +x otelcol_linux_amd64
Check the releases page for newer versions and substitute v0.155.0 accordingly.
A.3 Create the secrets file
Create ~/soc4kafka/collector.env and restrict its permissions. This keeps every secret out of the config file and out of process arguments.
cat > ~/soc4kafka/collector.env <<'EOF'
KAFKA_BOOTSTRAP=<KAFKA_BOOTSTRAP>
KAFKA_SASL_USER=<SASL_USERNAME>
KAFKA_SASL_PASS='<OCI_AUTH_TOKEN>'
SPLUNK_HEC_URL=<SPLUNK_HEC_ENDPOINT>
SPLUNK_HEC_TOKEN=<SPLUNK_HEC_TOKEN>
SPLUNK_INDEX=<SPLUNK_INDEX>
EOF
chmod 600 ~/soc4kafka/collector.env
Wrap KAFKA_SASL_PASS in single quotes so the shell does not expand special characters in the token value.
A.4 Create the collector config
Create ~/soc4kafka/config.yaml. Substitute <CONSUMER_GROUP> and <TOPIC> directly in the file; these aren't secrets and don't need to live in the env file.
This is an example of a simple configuration to get data flowing. The kafka receiver and splunk_hec exporter both support many more settings. See the README configuration table and the kafkareceiver / splunkhecexporter upstream docs to explore them.
receivers:
  kafka:
    brokers:
      - ${env:KAFKA_BOOTSTRAP}
    group_id: <CONSUMER_GROUP>
    client_id: <CONSUMER_GROUP>
    group_rebalance_strategy: range
    initial_offset: earliest
    tls:
      insecure_skip_verify: false
    auth:
      sasl:
        username: ${env:KAFKA_SASL_USER}
        password: ${env:KAFKA_SASL_PASS}
        mechanism: PLAIN
    logs:
      topics:
        - <TOPIC>
      encoding: text
processors:
  resourcedetection:
    detectors: [system]
    system:
      hostname_sources: ["os"]
exporters:
  splunk_hec:
    token: ${env:SPLUNK_HEC_TOKEN}
    endpoint: ${env:SPLUNK_HEC_URL}
    source: oci-streaming
    sourcetype: oci:streaming:text
    index: ${env:SPLUNK_INDEX}
    tls:
      insecure_skip_verify: true
    splunk_app_name: soc4kafka
    sending_queue:
      enabled: true
      num_consumers: 10
      queue_size: 10000
      block_on_overflow: true
      sizer: items
      batch:
        min_size: 1000
service:
  pipelines:
    logs:
      receivers: [kafka]
      processors: [resourcedetection]
      exporters: [splunk_hec]
A.5 Verify the connectivity before starting
Check that the VM can reach Splunk HEC:
nc -vz <SPLUNK_HEC_HOST> 8088
Confirm HEC accepts a posted event:
set -a; source ~/soc4kafka/collector.env; set +a
curl -kv \
  -H "Authorization: Splunk $SPLUNK_HEC_TOKEN" \
  -d '{"event":"hello","index":"'"$SPLUNK_INDEX"'"}' \
  "$SPLUNK_HEC_URL/event"
Expect {"text":"Success","code":0}. An Invalid token or Incorrect index error means Splunk setup needs fixing before you go further.
Check that the VM can reach the Kafka broker and authenticate - the single best end-to-end connectivity test, since success means DNS, routing, TLS, and SASL all work:
kafkacat -L \
  -b "$KAFKA_BOOTSTRAP" \
  -X security.protocol=SASL_SSL \
  -X sasl.mechanisms=PLAIN \
  -X sasl.username="$KAFKA_SASL_USER" \
  -X sasl.password="$KAFKA_SASL_PASS" | head -20
You should see <TOPIC> listed. If it times out or returns an auth error, resolve that before proceeding - the collector will exhibit the same failure.
A.6 Start the collector
Run in the foreground first to watch startup logs:
cd ~/soc4kafka
set -a; source ./collector.env; set +a
./otelcol_linux_amd64 --config config.yaml
A healthy startup looks like:
Everything is ready. Begin running and processing data.
...joined, balancing group   group: <CONSUMER_GROUP>
...synced                    assigned: <TOPIC>[0]
...beginning heartbeat loop
If you see NOT_COORDINATOR repeating, stop the collector, change group_id and client_id to a new name, and restart.
A.7 Install as a systemd service
After the collector starts cleanly, promote it to a managed service so it restarts automatically and its logs land in journald.
sudo mkdir -p /opt/soc4kafka /etc/soc4kafka
sudo cp ~/soc4kafka/otelcol_linux_amd64 /opt/soc4kafka/
sudo cp ~/soc4kafka/config.yaml /opt/soc4kafka/
sudo cp ~/soc4kafka/collector.env /etc/soc4kafka/collector.env
sudo chmod 600 /etc/soc4kafka/collector.env
sudo useradd --system --no-create-home --shell /usr/sbin/nologin otel
sudo chown otel:otel /opt/soc4kafka/otelcol_linux_amd64
sudo chown otel:otel /opt/soc4kafka/config.yaml
sudo chown otel:otel /etc/soc4kafka/collector.env
sudo tee /etc/systemd/system/soc4kafka.service > /dev/null <<'EOF'
[Unit]
Description=SOC4Kafka collector (OCI Streaming -> Splunk)
After=network-online.target
Wants=network-online.target
[Service]
User=otel
Group=otel
EnvironmentFile=/etc/soc4kafka/collector.env
ExecStart=/opt/soc4kafka/otelcol_linux_amd64 --config /opt/soc4kafka/config.yaml
Restart=on-failure
RestartSec=5s
[Install]
WantedBy=multi-user.target
EOF
sudo systemctl daemon-reload
sudo systemctl enable --now soc4kafka
sudo journalctl -u soc4kafka -f
A.8 Send a test message and confirm in the Splunk platform
printf '{"hello":"splunk","ts":"%s"}\n' "$(date -u +%FT%TZ)" | \
  kafkacat -P \
    -t <TOPIC> \
In Splunk search: index=<SPLUNK_INDEX> sourcetype=oci:streaming:text
You can also watch collector throughput on the VM - receiver_accepted_log_records_total should increment when you produce, followed shortly by exporter_sent_log_records_total as the batch flushes:
curl -s http://127.0.0.1:8888/metrics | grep -E
'otelcol_(receiver_accepted|exporter_sent)'
This guide uses MicroK8s as a representative single-node Kubernetes setup. The SOC4Kafka Helm chart is distribution-agnostic and runs on any conformant cluster. If you're on something else, swap in your cluster's regular kubectl/helm for the microk8s kubectl/microk8s helm3 commands below. The DNS pin and the OCI-host-firewall fix in this section are specific to running MicroK8s on an OCI VM; skip them on other clouds/distros.
MicroK8s ships its own bundled helm3 and kubectl. The commands below use microk8s helm3 and microk8s kubectl — not the system-level tools.
B.1 Install MicroK8s
sudo snap install microk8s --classic --channel=1.33/stable
sudo usermod -a -G microk8s "$USER"
sudo chown -f -R "$USER" ~/.kube
newgrp microk8s
microk8s enable hostpath-storage
microk8s enable rbac
microk8s enable metrics-server
Enable DNS pinned to the OCI VCN resolver, 169.254.169.254 - the same address in every OCI VCN. It answers both private OCI names (your broker's private endpoint) and public names (your Splunk HEC host), so using it as the single upstream matters:
microk8s enable dns:169.254.169.254
Don't add a public resolver like `8.8.8.8` alongside it. The OCI Streaming broker resolves to a private VCN IP, and a public resolver returns NXDOMAIN for it. If CoreDNS load-balances across both, you'll see intermittent connection failures—roughly half your lookups fail.
B.2 Fix the OCI host firewall
The OCI Ubuntu image ships a firewall rule that blocks forwarded traffic, which prevents pods from reaching the Kubernetes API server and causes CoreDNS and Calico to crash-loop (no route to host to the ClusterIP). Remove it:
sudo iptables -L FORWARD -n --line-numbers | head
sudo iptables -D FORWARD 1    # removes the REJECT rule (usually at position 1)
Pods recover within about 60 seconds. Make the fix permanent; the rule returns on reboot otherwise:
# Edit the persisted ruleset and remove the REJECT line, then reload:
sudo grep -nE 'REJECT|icmp-host-prohibited' /etc/iptables/rules.v4
# Delete the matching line from the file, then:
sudo netfilter-persistent reload
On a test VM, you can instead disable the OS firewall entirely. The OCI VCN security list still controls ingress at the cloud layer:
sudo systemctl disable --now netfilter-persistent
If Calico still crash-loops after removing the FORWARD rule, your image also has an INPUT-chain REJECT that blocks pod traffic to the Kubernetes API server VIP (10.152.183.1) and pod CIDR (10.1.0.0/16) — standard MicroK8s defaults. Allow them:  ``bash sudo iptables -I INPUT 4 -s 10.152.183.0/24 -j ACCEPT sudo iptables -I INPUT 4 -d 10.152.183.0/24 -j ACCEPT sudo iptables -I INPUT 4 -s 10.1.0.0/16    -j ACCEPT sudo iptables -I INPUT 4 -d 10.1.0.0/16    -j ACCEPT `  -I INPUT 4 inserts before the catch-all REJECT — confirm the position with sudo iptables -L INPUT -n --line-numbers first. If you customized MicroK8s CIDRs, use your actual service CIDR (grep service-cluster-ip-range /var/snap/microk8s/current/args/*) and pod CIDR (grep cluster-cidr /var/snap/microk8s/current/args/*`) instead.
B.3 Create the namespace
microk8s kubectl create namespace soc4kafka
B.4 Create the Kubernetes secrets
The collector reads credentials from Kubernetes Secrets injected as environment variables; they never appear in the Helm values file. The key names below are required by the chart. Don't rename them.
# Kafka SASL password — the key name "password" is required by the chart
microk8s kubectl -n soc4kafka create secret generic kafka-sasl \
  --from-literal=password='<OCI_AUTH_TOKEN>'
# Splunk HEC token — the key name "splunk-hec-token" is required by the chart
microk8s kubectl -n soc4kafka create secret generic splunk-hec \
  --from-literal=splunk-hec-token='<SPLUNK_HEC_TOKEN>'
Wrap values in single quotes to prevent the shell from interpreting special characters. And remember the earlier note: if <OCI_AUTH_TOKEN> starts with a YAML-special character, regenerate it before creating this secret.
B.5 Create values.yaml
Create this file on the VM (for example, at ~/soc4kafka_microk8s/values.yaml). Substitute all <PLACEHOLDERS> with your real values.
This is an example of a simple configuration to get data flowing. The Helm chart supports many more settings for receivers, exporters, TLS, and secrets. See the chart's configuration, secrets, and TLS docs to explore them
replicaCount: 1
kafkaReceivers:
  - name: main
    brokers:
      - <KAFKA_BOOTSTRAP>
    client_id: <CONSUMER_GROUP>       # e.g. soc4kafka-m8k-v1 — must be fresh
    logs:
      topics:
        - <TOPIC>
      encoding: text
    auth:
      sasl:
        username: <SASL_USERNAME>
        mechanism: PLAIN
        secret: kafka-sasl           # references the Secret created in step B.4
    tls:
      insecure_skip_verify: false    # OCI broker cert is publicly trusted
splunkExporters:
  - name: primary
    endpoint: <SPLUNK_HEC_ENDPOINT>
    secret: splunk-hec               # references the Secret created in step B.4
    index: <SPLUNK_INDEX>
    tls:
      insecure_skip_verify: true    # Splunk default self-signed cert has no SAN
    sending_queue:
      enabled: true
      num_consumers: 10
      queue_size: 10000
      sizer: items
      batch:
        min_size: 1000
pipelines:
  - name: oci-to-splunk
    type: logs
    receivers: [main]
    exporters: [primary]
extraEnv:
  - name: KAFKA_KAFKA_MAIN_SASL_PASSWORD
    valueFrom:
      secretKeyRef:
        key: password
resources:
  limits:
    cpu: 500m
    memory: 512Mi
  requests:
    cpu: 100m
    memory: 256Mi
collectorLogs:
  enabled: false
collectorMetrics:
  enabled: false
B.6 Install the chart
microk8s helm3 repo add splunk-opentelemetry-collector-for-kafka \
  https://splunk.github.io/splunk-opentelemetry-collector-for-kafka
microk8s helm3 repo update
microk8s helm3 upgrade --install soc4kafka \
  splunk-opentelemetry-collector-for-kafka/splunk-opentelemetry-collector-for-kafka \
  -n soc4kafka \
  -f ~/soc4kafka_microk8s/values.yaml
Always include -n soc4kafka. Without it the release lands in the default namespace and will be difficult to find.
B.7 Verify the deployment
Check that all pods are running:
microk8s kubectl get pods -A
Tail the collector logs and look for the healthy startup sequence:
microk8s kubectl -n soc4kafka logs -f \
  deploy/soc4kafka-splunk-opentelemetry-collector-for-kafka
Expected output:
franz   joined, balancing group   group: <CONSUMER_GROUP>
franz   synced                    assigned: <TOPIC>[0]
franz   assigning partitions      ...
If you see NOT_COORDINATOR repeating, change client_id and group_id to a new name in values.yaml and re-run the helm3 upgrade command from step B.6.
B.8 Send a test message and confirm in the Splunk platform
Produce a message from the VM (install kafkacat first if needed: sudo apt-get install -y kafkacat):
echo "hello-from-microk8s-$(date -Is)" | kafkacat -P \
  -b <KAFKA_BOOTSTRAP> \
  -t <TOPIC> \
  -X sasl.username='<SASL_USERNAME>' \
  -X sasl.password='<OCI_AUTH_TOKEN>' \
  -X ssl.ca.location=/etc/ssl/certs/ca-certificates.crt
Alternatively, use the OCI Console: StreamingStreamsselect streamProduce Test Message
In Splunk search: index=<SPLUNK_INDEX> sourcetype="oci:streaming:text" earliest=-5m
Verifying TLS on the Kafka leg
Both deployments encrypt the Kafka connection, but encryption isn't the same as verification. Verification means the collector actually checks the certificate chain and hostname. This is worth doing once you have data flowing.
The collector is written in Go, and Go's TLS stack ignores the certificate's Common Name (CN) and requires a Subject Alternative Name (SAN) instead. A certificate with no SAN fails verification with x509: certificate relies on legacy Common Name field, use SANs instead, regardless of whether you connect by IP or hostname.
The good news: OCI Streaming's broker certificate is issued by DigiCert (already trusted by the collector's CA bundle) and typically carries a SAN covering the broker's hostname. That's why both configs above already set insecure_skip_verify: false on the Kafka receiver. To confirm the SAN covers your specific broker hostname, run this from the VM (or a pod) that can reach the broker:
openssl s_client \
  -connect <KAFKA_BOOTSTRAP> \
  -servername <broker-fqdn> </dev/null 2>/dev/null \
  | openssl x509 -noout -ext subjectAltName
If the SAN includes your broker's hostname (or a wildcard covering it), verification will pass with insecure_skip_verify: false, no further changes needed. If you see a trust error instead, you can force the system CA bundle explicitly:
tls:
  ca_file: /etc/ssl/certs/ca-certificates.crt
Troubleshooting quick reference
Symptom Cause Fix
NOT_COORDINATOR repeating on join  Consumer group ID left in a stale/poisoned state  Use a fresh group_id / client_id and redeploy
password is required despite a correct secret  Token starts with a YAML-special char (for example, #); the collector's env provider re-parses it as YAML and the value collapses to null Regenerate the OCI auth token so it doesn't start with #, &, *, !, >, |, @, `, then recreate the secret and restart
SASL authentication error: Authentication failed with a valid token Tenancy uses an OCI identity domain; the 3-part username is missing the domain segment  Use <tenancy-namespace>/<identity-domain>/<user>/<stream-pool-OCID>
Splunk HEC exporter hangs / connection timed out Splunk host firewall doesn't allow inbound 8088 from the collector's IP  Open that inbound rule; confirm with nc -vz <SPLUNK_HEC_HOST> 8088
(MicroK8s) Pods CrashLoop with no route to host to the ClusterIP  OCI Ubuntu image's FORWARD-chain REJECT blocks pod traffic  Remove the rule (see B.2); also check the INPUT-chain REJECT if Calico still crashes
(MicroK8s) Pod DNS times out or returns NXDOMAIN for the broker A public resolver (for example, 8.8.8.8) is mixed in with the OCI resolver Use only 169.254.169.254 as the CoreDNS upstream
Broker closes connection: requires TLS but client is using plaintext
tls: block was nested under
auth: instead of being top-level on the receiver
Move tls: to be a top-level key of the kafka receiver
max version 5 below the user defined min of 11 protocol_version pinned to a newer Kafka API version than OCI Streaming advertises  Don't set protocol_version at all
Additional resources
The same collector binary and Helm chart work unmodified against other clouds and Kubernetes distributions, only connectivity and DNS configuration change. If OCI Streaming and your Splunk instance sit in different clouds or accounts, the concepts above still apply; you'll just need to handle DNS resolution and network routing between them.
