Hosts logging more or less data than expected
You might need to know how much data hosts logged to your network when doing the following:
The data needed in this procedure depends on the types of events you are investigating. The data descriptors can help you decide what data is appropriate for your goal.
An anomaly occurred on your network in the last 3 hours. Your boss wants a report of how much data each host on the network logged during that time, along with some sort of baseline for comparison.
  1. Run the following search:
|tstats count WHERE earliest =-7d latest=-3h BY host, _time span=3h
|stats median(count) AS median BY host
|join host [|tstats count WHERE earliest=-3 BY host]
|eval percentage_diff=((count/median)*100)-100
|where percentage_diff<-5 OR percentage_diff>5
|sort percentage_diff
|rename median AS "Median Event Count Past Week", count AS "Event Count of Events Past 3 Hours", percentage_diff AS "Percentage Difference"
Return the number of events per host in the last seven days up until three hours ago, batched into three-hour intervals.
Return the median number of events for each host. If you use a visualization, the median will be on the y-axis and the hosts will be on the x-axis.
Return the number of events in the last three hours per host, and display those results with the previous results.
Calculate the percentage difference between the median number of events over the seven-day period and the events in the last three hours for each host.
Return values where the percentage difference is less than -5 or greater than 5.
Sort the table with the least percentage difference value first.
Rename the fields as shown for better readability.
The results include everything your boss asked for, as well as the percentage difference in data logged. You can print or export the results table, or click Save As > Report to save it for viewing in Splunk. Printing or saving the results as a visualization, such as a line chart, might be more useful.
