First time accessing an internal Git repository
You might need to find users who accessed a Git repository for the first time when doing the following:
Developers are often granted access to the Git (or other software life cycle repository) that their responsibilities require. The first time a user accesses a given repository could be perfectly normal, or if the repository contains code not relevant to the developers role, could be an anomaly to investigate. You want to monitor first access instances so you can investigate if needed.
To optimize the search shown below, you should specify an index and a time range. In addition, this sample search uses atlassian-bitbucket as a source. You can replace this source with any other web server data used in your organization.
  1. Run the following search:
source="*/atlassian-bitbucket-access.log"
|rex "GET /projects/[^/]*/repos/(?<git_repo>[^/]*)"
|rex "(?<git_repo>[^/]*)\.git"
|rex "git\.[^ /]{1,}/projects/[^/]*/repos/(?<git_repo>[^/]*)"
|search  git_repo="*"
|stats earliest(_time) AS earliest latest(_time) AS latest  BY user, git_repo
|where earliest > relative_time(now(), "-1d@d")
Pull in your Git dataset.
Your may be different from the Atlassian sample shown here. Update the source according to your environment.
Extract the field names.
These regular expressions have worked in a couple of environments, but you may need to adapt them to yours.
|search  git_repo="*"
Filter for logs that include a git_repo field.
Calculate the earliest and the latest time that the repos were accessed.
Return results where the earliest time was within the last day.
While there are no traditional false positives in this search, every time this fires, it will accurately reflect the first occurrence in the time period you're searching over (or for the lookup cache feature, the first occurrence over whatever time period you built the lookup). You should not review these alerts directly (except for access to extremely sensitive repositories), but instead use them for context, or to aggregate risk.
When this search returns values, initiate your incident response process and identify the user account accessing the specific repo. Contact the user and manager to determine if they are accessing the repo with authorization. If they did not access this repo, attempt to determine if the user credentials have been used by another party by stealing a user's credentials.
