Increase in source code downloads
You might need to find users who have downloaded more files from Git than normal when doing the following:
Your organization uses Git to version source code. Developers only have access to repositories they need for their projects, but even good access restrictions can't prevent all data exfiltration. You want to monitor Git access for downloads so you can validate that downloads are normal or identify download activity that needs to be investigated.
To optimize the search shown below, you should specify an index and a time range. In addition, this sample search uses atlassian-bitbucket as a source. You can replace this source with any other web server data used in your organization.
  1. Run the following search:
source="*/atlassian-bitbucket-access.log"
|bucket _time span=1d
|stats count BY user _time
|stats count AS num_data_samples max(eval(if(_time >= relative_time(maxtime, "-1d@d"), 'count',null))) AS count avg(eval(if(_time<relative_time(maxtime,"-1d@d"),'count',null))) AS avg stdev(eval(if(_time<relative_time(maxtime,"-1d@d"),'count',null))) AS stdev BY user
|eval lowerBound=(avg-stdev*2), upperBound=(avg+stdev*2)
|where 'count' > upperBound AND num_data_samples >=7
Pull in your Git dataset.
Collect all events occurring in a one-day span.
Count the downloads and aggregate them per user, per day.
Calculate the mean, standard deviation, and most recent value.
Calculate the bounds as a multiple of the standard deviation.
Return results where the count is greater than the upper bound.
While there are no traditional false positives in this search, there will be a lot of noise, based on the bursty nature of source code access. When someone first clones a repository, their counts will be excessive. This search provides contextual data to record when these big bursts of activity occur.
When this search returns values, initiate your incident response process and validate the user account accessing the specific repos. Contact the user and their manager to determine if it is authorized, and make a note if it is authorized and by whom. If not, the user credentials may have been used by another party and additional investigation is warranted as repositories hold sensitive source code.
Run this search once a day, preferably overnight. If you want to run this search more frequently, or if this search is too slow for your environment, use a summary index that first aggregates the data.
It is particularly interesting to correlate this behavior to a watchlist that contains the user IDs of personnel that are considered higher risk: contractors, new employees, employees that never go on vacation, and employees with access to particularly sensitive source code.
