Spoolsv suspicious loaded modules
You might need to search for spoolsv.exe suspicious loaded modules when doing the following:
Some attacks such as PrintNightmare perform module loads into Spoolsv.exe based on dll loading from a specific path. This search detects the loaded modules made by spoolsv.exe after the exploitation.
  1. Ensure you have at least version 6.0.4 of the Sysmon TA.
  2. Run the following search:
sourcetype=XmlWinEventLog:Microsoft-Windows-Sysmon/Operational OR source=XmlWinEventLog:Microsoft-Windows-Sysmon/Operational
EventCode=7 Image ="*\\spoolsv.exe" ImageLoaded="*\\Windows\\System32\\spool\\drivers\\x64\\*"
ImageLoaded = "*.dll"
| stats dc(ImageLoaded) AS countImgloaded values(ImageLoaded) AS ImgLoaded count min(_time) AS firstTime max(_time) AS lastTime BY Image Computer EventCode
| where countImgloaded >= 3
Search Sysmon operational data.
EventCode=7 Search for when a module is loaded in a specific process.
Image ="*\\spoolsv.exe" ImageLoaded="*\\Windows\\System32\\spool\\drivers\\x64\\*" ImageLoaded = "*.dll" Search for modules related to spoolsv.exe.
| stats dc(ImageLoaded) AS countImgloaded values(ImageLoaded) AS ImgLoaded count min(_time) AS firstTime max(_time) AS lastTime BY Image Computer EventCode  Return the number of times each distinct image was loaded, the name of image loaded, and the first and last time each image was loaded, renaming the fields as shown. Then  sort the results by the computer and the event code.
| where countImgloaded >= 3 Return results only when 3 or more modules are loaded by the exploit (unidrv.dll, kernelbase.dll, and the suspect dll) at the same time in the specific target folder.
Ensure you filter for false positives on this search.
During triage, isolate the endpoint and review for source of exploitation. Capture any additional file modification events.
If your results indicate an attack has occurred, the host or computer where the vulnerability is detected needs to be further investigated and remediated according to your response plan. This involves a final step of re-imaging the system with a known good system build after investigation.
