Riskiest ATM users
You might want to calculate risk scores for ATM users when doing the following:
Finding out who are riskiest users can help determine whether their questionable transaction activity may be involved in fraud. For each ATM your company manages, you need to calculate a risk score for each user so you can create a watchlist of users to monitor.
To optimize the search shown below, you should specify a time range.
  1. Run the following search:
    |inputlookup <name of lookup file for ATM transaction information>
    |lookup <name of lookup file for ATM user risk scores> user OUTPUT score
    |stats sum(score) AS Risk_Score count BY user
    |sort - Risk_Score
    |head 5
|inputlookup <name of lookup file for ATM transaction information> Search the data in your ATM transaction information lookup file.
Perform a lookup to get risk scores per user.
If your lookup file does not contain user and score columns, adjust the search to match the names in your lookup.
|stats sum(score) AS Risk_Score count BY user Sum the risk scores and counts for each user.
|sort - Risk_Score Sort the results with the highest risk score first.
|head 5 Return the 5 riskiest users.
Create searches and alerts to watch the transactions that your risky users make. Be sure to take any steps necessary to meet compliance and procedural regulations.
