Excessive number of credit card transactions in a short period
You might need to monitor for an excessive number of credit card transactions when doing the following:
You work at a financial institution in the fraud department. You know that too many transactions in one minute could indicate a stolen card, so you want to run a regular report to monitor for this behavior.
To optimize the search shown below, you should specify a time range. You may also need to adjust fields to match what is available in your data source.
  1. Run the following search:| sourcetype=<customer information data source>
    | eval _time=strptime('_time',"%Y/%m/%d %H:%M:%S")
    | sort - _time
    | streamstats earliest(_time) AS _time latest(_time) AS latest_time time_window=1m count(action) AS num_transactions BY customer
    | where (num_transactions >= 10)
    | eval latest_time=strftime(latest_time,"%Y-%m-%d %H:%M:%S")
    | dedup customer
    | table customer, _time, latest_time, num_transactions, category
| sourcetype=<customer information data source> Search only your business service data for customer information.
| eval _time=strptime('_time',"%Y/%m/%d %H:%M:%S") Parse the time stamp into a UNIX time value .
| sort - _time Sort the results from oldest to newest.
| streamstats earliest(_time) AS _time latest(_time) AS latest_time time_window=1m count(action) AS num_transactions BY customer Report cumulative time and transaction count statistics in one-minute increments, renaming the fields as shown and with results grouped by customer.
| where (num_transactions >= 10) Return only events where the number of transactions is greater than or equal to 10.
| eval latest_time=strftime(latest_time,"%Y-%m-%d %H:%M:%S") Convert the UNIX time value into a human-readable string.
| dedup customer
Remove duplicate customer results.
| table customer, _time, latest_time, num_transactions, category Display the results in a table with columns in the order shown.
Run a regular report for which customers have used their card too frequently over a one minute interval. Too much use of the credit card in a short window may indicate a stolen card going on a shopping spree.
