Large and rapid credit card spending
You might need to monitor for high value credit card spending on a large number of transactions when doing the following:
You work for a credit card provider and need to monitor consumer transactions to prevent fraud. You know that one indicator is when a card is used to make a lot of purchases in a short time span, especially when the purchases are for large dollar amounts.
To optimize the search shown below, you should specify a time range. You may also need to adjust fields to match what is available in your data source.
  1. Run the following search:| sourcetype=<customer information data source>
    | eval _time=strptime('_time',"%Y/%m/%d %H:%M:%S")
    | sort - _time
    | streamstats earliest(_time) AS _time latest(_time) AS latest_time time_window=1m count(action) AS num_transactions sum(amount) AS total_spent BY customer
    | where ((total_spent > 5000) AND (num_transactions >= 5))
    | eval latest_time=strftime(latest_time,"%Y/%m/%d %H:%M:%S"), total_spent=tostring(round(total_spent,2),"commas")
    | table customer, _time, latest_time, num_transactions, total_spent, category
Search only your business service data for customer information.
Parse the time stamp into a UNIX time value.
| sort - _time
Sort the results from oldest to newest.
Report cumulative time, count, and monetary value statistics in one-minute increments, renaming the fields as shown.
Filter results to show only those that have a transaction amount greater than 5000 and at least 5 total transactions within the defined time period.
| eval latest_time=strftime(latest_time,"%Y/%m/%d %H:%M:%S"),total_spent=tostring(round(total_spent,2),"commas")
Convert the UNIX time value into a human-readable string. Then convert the dollar spending amounts to strings rounded to two values and using a comma when needed.
If the search returns results, alert the customer right away to prevent further fraud. This could be a bot or a stolen credit card.
