Dormant bank accounts
You might need to run a regular report that shows which accounts are dormant when doing the following:
Customers having dormant accounts can sometimes cause a compliance issue for banks. This report provides just-in-time information so that at the time of an account transaction, you can inform the customer if they have any untouched accounts older than 6 months from their current transaction date.
To optimize the search shown below, you should specify a time range. You may also need to adjust fields to match what is available in your data source.
  1. Run the following search:
    |sourcetype=<transaction data source>
    |eval prev_epoch=strptime(last_touched, "%m/%d/%Y %H:%M:%S")
    |sort - last_touched
    |join customer [ |inputlookup <customer account info file> ]
    |where epoch>relative_time(prev_epoch, "+6mon")
    |fields - prev_epoch, balance|rename accountID AS current_accountID action AS current_action account_type AS current_account_type
    |eval current_balance=tostring(round(current_balance, 2),"commas"), other_balance=tostring(round(other_balance, 2),"commas")
    |convert timeformat="%m/%d/%Y %H:%M:%S" ctime(epoch) AS current_time
    |fields - epoch
|sourcetype=<transaction data source> Search only your business service data for bank transactions .
|eval prev_epoch=strptime(last_touched, "%m/%d/%Y %H:%M:%S") Parse the time stamp for the last time the account was accessed into a UNIX time value.
|sort - last_touched Sort the results from oldest to newest.
Look up the other accounts for the customer and join the results.
|where epoch>relative_time(prev_epoch, "+6mon") Filter results to accounts whose last_touched date is at least 6 months greater than the current transaction date.
|fields - prev_epoch, balance Remove the fields shown from the results.
|rename accountID AS current_accountID action AS current_action account_type AS current_account_type Rename the fields as shown for better readability.
|eval current_balance=tostring(round(current_balance, 2),"commas"), other_balance=tostring(round(other_balance, 2),"commas") Convert the balances to strings rounded to two values, using a comma when needed.
|convert timeformat="%m/%d/%Y %H:%M:%S" ctime(epoch) AS current_time Convert the epoch time to a human readable time and output to a field called current_time.
|fields - epoch Remove the epoch field from the results.
Every time a customer performs an account transaction, inform them about their other accounts. If any account is dormant, let them know so they can take corrective action.
