Uncommon top level domains
You might want to be able to extract uncommon top level domains from your data when doing the following:
You recently started work as a Security Analyst for a company whose users often access websites that don't use the Latin alphabet. You need to be able to accurately extract all URLs from your data.
To optimize the search shown below, you should specify an index and a time range. In addition, this sample search uses Palo Alto Networks data. You can replace this source with any other firewall data used in your organization.
  1. Run the following search:
sourcetype=pan:threat
| stats count BY url
| urlparser field=url listname="mozilla" mode=extended
Explanation
Search only threat events from Palo Alto Networks data.
| stats count BY url
Show the event count for each value in the url field.
Use the URLParser app to extract domains from the Mozilla catalog.
These are the default settings for the URLParser. Searching | urlparser will yield the same results as specifying the parameters shown here.
The results show the URLs visited by your users, but it doesn't separate the legitimate ones from the suspicious ones. Use your own lookup tables to help sort through the results, or use the analytic functions of the URL Toolbox app, like Shannon Entropy, to find URLs that you need to investigate.
