Splunk Lantern is currently being updated. If you notice anything unusual, it should resolve soon, but you can always report issues on our Community Slack. Thank you for your patience.
Setting Unix profiles
As a Splunk engineer, you may work with various Unix-based operating systems and correspondingly different standards and practices. In these environments, the Splunk installation may not be in the same location, which can make it difficult to use the Splunk command-line features needed for your job function. Because you cannot ask all operating systems to conform to one set of standards, a non-intrusive alternative is to use environment variables to mask such differences, creating a consistent and effective environment to work in.
Guidelines for implementing Splunk Unix profiles
The code examples here are unsupported and can vary depending on the Unix shell you use. Refer to the documentation for your Unix shell to ensure these guidelines are valid for your environment.
Use the following variables and commands to provide a consistent shell experience regardless of differences in the underlying operating system.
Set SPLUNK_HOME
Splunk can be installed in many locations. To normalize the variation of installation directories across instances, you can use a script to define and map them to SPLUNK_HOME.
The first line in the following example is pre-populated with some common installation locations. Modify this to match your needs.
for SPLUNK_HOME in "/Applications/Splunk" "/Applications/SplunkForwarder" "/opt/splunk" "/opt/splunkforwarder" "/Applications/SplunkBeta" "/Applications/SplunkForwarderBeta
" "${HOME}/splunkforwarder";do
        if [ -d ${SPLUNK_HOME} ]; then
                break
        fi
done
if [ "${SPLUNK_HOME}" == "" ];then
        echo "WARNING: SPLUNK_HOME env variable undefined"
fi
export SPLUNK_HOME
Set history control
Unix keeps command line history. This can be troublesome from a security standpoint when Splunk commands require that you enter a username and password at the command line. The Unix variable HISTCONTROL controls how the shell terminal stores command history. Set the HISTCONTROL variable in your environment and use the flag ignorespace to ignore commands that have a leading space. Run the Splunk commands that use a username and password with a leading space so they won't persist to the history.
HISTCONTROL=ignorespace
Add Splunk to PATH
You do not have to navigate to ${SPLUNK_HOME}/bin every time to run ./splunk! You can add items to your PATH to reference wherever your command line navigation takes you.
export PATH=$PATH:/usr/bin:$SPLUNK_HOME/bin
Add btool to PATH
The troubleshooting utility btool is powerful, but you might avoid using it because you have to remember how to navigate to it. By adding btool to your PATH, you can call upon it wherever and whenever you need it. For more about btool and how to use it, see Use btool to troubleshoot configurations.
KERNEL=`uname -s`
case "x$KERNEL" in
        "xLinux")
                if [ -f /etc/lsb-release -o -d /etc/lsb-release.d ]; then
                        export DISTRO=$(lsb_release -i | cut -d: -f2 | sed s/'^\t'//)
                else
                        export DISTRO=$(ls -d /etc/[A-Za-z]*[_-][rv]e[lr]* | grep -v "lsb" | cut -d'/' -f3 | cut -d'-' -f1 | cut -d'_' -f1)
                fi
                if [ "x$DISTRO" != "xUbuntu" ];then
                        export LD_LIBRARY_PATH=$SPLUNK_HOME/lib
                fi
        "xDarwin")
                export DYLD_LIBRARY_PATH=$SPLUNK_HOME/lib
                echo "ERROR: Unable to set LIBRARY_PATH"
                exit 1
esac
Prompt string 1 (PS1)
PS1 is the primary prompt that is displayed before each command. If you have Splunk instances distributed on systems with OS variations, having consistent PS1 prompt information from system to system can save time and reduce mistakes. Here are some suggestions about what variables to set and why so you have the same prompt information for each OS variation you work with.
PS1="[\`date\`] [\u@\h \w]\n> "
  • Use brackets and special characters as needed to format the prompt string, for example, '[ ]', '@', and '>'
  • Use > as the prompt character because it resembles the Splunk logo
  • Use [\`date\`] to automatically execute a timestamp on every command prompt so you can have an approximate timeframe of the commands you issue on that system
  • \u includes the username of the current user
  • \h includes the host name the user is working from up to to the first period '.'
  • \w includes the fully qualified path of the current working directory
  • \n establishes a new line to make the results easy to read
Template for Splunk Unix profiles
The following template contains all the variables and commands listed in these guidelines. Edit it for your needs.
#History Control
#Set SPLUNK_HOME
                break
        fi
done
fi
export SPLUNK_HOME
#Add splunk to PATH
#Add btool to PATH
KERNEL=`uname -s`
case "x$KERNEL" in
        "xLinux")
                else
                fi
                fi
        "xDarwin")
                exit 1
esac
#Prompt String 1 (PS1)
#EOF
Simplify distribution of the shell profile using the deployment server
You can leverage these shell commands on all your deployment clients using the deployment server. You can push out the shell profile with an app that contains the shell script in a bin directory. To leverage the shell profile on each deployment client, add a line to the Unix account's existing shell profile to "source" (or load) your creation from its deployment target.
Append the following to the default profile of the Unix user:
#Load Splunk-specific profile
. /path/to/splunk/etc/apps/my_unix_profile/bin/splunk_profile
