Following data onboarding best practices
Implementing standardized data onboarding procedures in the Splunk platform ensures that data is ingested and managed consistently.
In this article, you will learn about the following data onboarding best practices:
- Data validation
- Great 8 configurations
- Data normalization
- Data enrichment
- Data transformation
- Versioning and auditing
- Data quality monitoring
- Documentation
Data validation
Data validation ensures that the data being ingested into the Splunk platform is accurate, reliable, and adheres to predefined standards. These qualities set the foundation for accurate data analysis, reporting, and decision-making. Here's a more detailed explanation of the key aspects of data validation:
- Data Format Correctness: Validate that the data is in the expected format. This includes verifying that date and time formats, numerical values, and string formats are correct. For example, if your data requires a specific date format (such as YYYY-MM-DD), a validation script should flag any data entries that don't adhere to this format.
- Completeness: Check for missing or incomplete data. Ensure that all required fields are present and populated with valid values. For instance, if certain fields are mandatory for analysis, the validation process should identify records where these fields are missing.
- Data Integrity: Verify the integrity of the data by checking for inconsistencies or errors within the dataset. This could involve cross-referencing related fields to ensure they align logically. For example, if you have a dataset with customer orders, the validation process could verify that the total order amount matches the sum of individual line items.
- Adherence to Standards: Ensure that the data conforms to predefined standards, both internal and industry-specific. This might involve checking against defined naming conventions, units of measurement, or any other guidelines that are relevant to your organization's data practices. For more guidance, see the Open Worldwide Application Security Project (OWASP) Logging Cheat Sheet.
- Custom Validation Rules: Depending on the nature of your data, you might need to implement custom validation rules. These rules could involve complex business logic that checks for specific conditions or patterns within the data.
- Data Enrichment and Transformation Validation: If you perform any data enrichment or transformation during the onboarding process, validate that these processes are working as intended. Ensure that the enriched or transformed data still aligns with your validation criteria.
To implement data validation effectively, you can use validation scripts or tools. These scripts can be programmed to automatically run checks on the incoming data and flag any issues that are identified. The flagged data can then be reviewed and corrected before being ingested into the Splunk platform. Automation of this process not only saves time but also reduces the risk of human errors in the validation process.
The props.conf configuration file is a power configuration option for controlling how data is ingested, parsed, and transformed during the onboarding process. Among other things, props.conf is used for defining field extractions, identifying and capturing specific pieces of information from your raw data.
The Great 8 configurations below provide a standard for transforming raw data into well formatted, searchable events within the Splunk platform. They ensure that events are accurately separated, timestamps are correctly captured, so that fields can be properly extracted for analysis. By adhering to these configurations, you enhance data consistency, accessibility, and reliability, setting the stage for accurate insights and efficient analysis.
The following list only provides a brief explanation of each of these configurations. For complete, hands-on configuration guidance, see Configuring new source types.
- SHOULD_LINEMERGE = false (always false): This configuration tells the Splunk platform not to merge multiple lines of data into a single event. This is particularly useful for log files where each line represents a separate event, preventing accidental merging of unrelated lines. For additional context, reference the
props.confspec around line breaking. - LINE_BREAKER = regular expression for event breaks: The LINE_BREAKER configuration specifies a regular expression pattern that indicates where one event ends and another begins. This is essential for parsing multi-line logs into individual events for proper indexing and analysis. For additional context, reference the
props.confspec around line breaking. - TIME_PREFIX = regex of the text that leads up to the timestamp: When data contains timestamps, TIME_PREFIX helps the Splunk platform identify the portion of the data that precedes the actual timestamp. This helps the Splunk platform correctly locate and extract the timestamp for indexing and time-based analysis.
- MAX_TIMESTAMP_LOOKAHEAD = how many characters for the timestamp: This configuration sets the maximum number of characters that the Splunk platform will look ahead from the TIME_PREFIX to find the timestamp. It ensures that the Splunk platform doesn't search too far ahead, optimizing performance while accurately capturing timestamps.
- TIME_FORMAT = strptime format of the timestamp: TIME_FORMAT specifies the format of the timestamp within the data. The Splunk platform uses this information to correctly interpret and index the timestamp, making it usable for time-based searches and analyses.
- TRUNCATE = 999999 (always a high number): TRUNCATE configuration helps prevent overly long events from causing performance issues. It limits the maximum length of an event, ensuring that extremely long lines don't negatively impact the performance of the Splunk platform.
- EVENT_BREAKER_ENABLE = true: This configuration indicates whether event breaking should be enabled. Setting it to true ensures that event breaking based on LINE_BREAKER is activated.
- EVENT_BREAKER = regular expression for event breaks: EVENT_BREAKER allows you to define an additional regular expression pattern for event breaking. This can be useful for scenarios where more complex event breaking is required.
Data normalization
Data normalization is a process of transforming data from various sources into a common and standardized format or structure. This is particularly important in the Splunk platform, as normalized data allows for consistent analysis, reporting, and integration across different data sources.
Data normalization process
- Consistent Format: Data can be received from diverse sources, each with its own format. During normalization, the data is transformed into a uniform format. For example, if different data sources use different date formats (MM/DD/YYYY and DD-MM-YYYY), normalization would involve converting them all to a standardized format (YYYY-MM-DD).
- Standardized Units: Normalize units of measurement to ensure consistency. This is particularly important when dealing with numerical data, such as converting measurements from metric to imperial units or vice versa.
- Field Naming Conventions: Ensure consistent field naming across different data sources. For example, if one source uses "IP_Address" and another uses "Source_IP," normalization involves mapping these variations to a single, standardized field name.
- Data Enrichment: As part of normalization, you might enrich data by adding contextual information.
Importance of data normalization in compliance with Splunk's Common Information Model (CIM)
In the context of CIM compliance, data normalization becomes even more crucial to ensure interoperability and consistency across different security-related data sources. CIM is a standardized framework for organizing data into a common format. It enables interoperability between different security solutions by providing a consistent model for data. When normalizing data for CIM compliance, you're aligning your data with CIM's predefined data structures, which allows for seamless integration and correlation of events across various sources.
For example, if you're collecting logs from different security devices like firewalls, intrusion detection systems, and antivirus solutions, each might have its own unique data structure. By normalizing the data to CIM's standard, you're ensuring that these different sources can be easily correlated and analyzed together.
In the context of the Splunk platform, data normalization for CIM compliance involves mapping your data fields to the CIM's standardized fields. This mapping ensures that your data fits into the CIM data model and can be effectively used with CIM-compliant apps and searches. CIM compliance enhances your ability to perform security analytics, threat detection, and incident response by providing a unified view of security-related data.
Data enrichment
Data enrichment is the process of enhancing existing data with additional context, information, or attributes to make it more valuable and meaningful for analysis and decision-making. In the context of the Splunk platform and data management, data enrichment plays a large role in improving the quality, relevance, and usability of the data you collect and analyze.
Context-based enrichment
- Geolocation Data: Adding geographical context to data can provide insights into the geographic origin of events. For example, enriching IP addresses with geolocation information can help you understand where certain activities are occurring.
- External Data Sources: Enriching data with information from external sources can provide a broader context. For instance, you might enrich user data with social media profiles or industry-related data to gain a better understanding of user behavior.
- Threat Intelligence Feeds: Enriching security-related data with threat intelligence feeds can help identify known malicious IPs, domains, or URLs, aiding in the early detection of potential security threats.
Business-specific logic enrichment
- Derived Fields: Enrichment can involve creating new fields or attributes based on existing data. For example, you might create a "Customer Segment" field based on customer purchase history and demographics.
- Calculated Fields: Enrichment can also include performing calculations on existing data to generate new insights. For instance, calculating the average transaction value from historical sales data can provide valuable business insights.
Benefits of enrichment
- Improved Analysis: Enriched data provides more context and depth, enabling more accurate and insightful analysis. This leads to better decision-making and actionable insights.
- Enhanced Correlation: Enrichment helps correlate data from different sources by adding common attributes. This is especially important in security and operational contexts where identifying relationships between events is crucial.
- Better Visualization: Enriched data can lead to more meaningful visualizations. For example, visualizing sales data enriched with customer demographics can reveal patterns and trends.
- Advanced Analytics: Enriched data supports advanced analytics, machine learning, and predictive modeling by providing a more comprehensive view of the data.
Methods of enrichment
- Lookup Tables: You can use lookup tables to enrich IP addresses with geolocation data.
- Scripted Inputs: You can use scripted inputs to fetch external data from API.
- Custom Search Commands: You can develop search commands to perform specific enrichments on data during analysis.
Data transformation
Data transformation can be a crucial step in the data management process, especially when dealing with data collected from diverse sources with varying structures and formats. In the context of the Splunk platform and data management, data transformation involves reshaping and reorganizing data to make it more suitable for analysis, reporting, and other purposes.
Key aspects of data transformation
- Aggregation: Aggregating data involves combining multiple data records into a summary or aggregated view. This can be done to calculate totals, averages, counts, or other aggregated metrics. For example, transforming daily sales data into monthly or quarterly aggregates can provide a higher-level overview.
- Field Merging: Sometimes, data from different sources might have related information stored in separate fields. Data transformation might involve merging these fields to consolidate related data. For instance, merging "First Name" and "Last Name" fields into a single "Full Name" field.
- Splitting Data: In some cases, data might need to be split into different dimensions for analysis. For example, transforming a date field into separate fields for year, month, and day can allow for time-based analysis.
- Normalization: Data normalization involves standardizing data values. This is especially important when dealing with data from multiple sources that use different units of measurement. For example, one system might use "usr_name" while another uses "username" to indicate a user's name; normalization would involve mapping these differing fields to a common field name, such as "user_name," to facilitate unified searches and analytics.
Benefits of data transformation
- Improved Analysis: Transformed data is more structured and aligned with analysis requirements, enabling more accurate and insightful results.
- Enhanced Compatibility: Transformation ensures that data from diverse sources can be integrated and analyzed together, even if they have different structures.
- Efficient Storage: Aggregating and summarizing data can lead to reduced data volumes, making storage more efficient.
- Simplified Reporting: Transformed data is often more suitable for creating reports and visualizations that highlight key insights.
Implementing version control for your data onboarding scripts and configurations is a crucial practice in data management and governance. Here's why versioning and auditing are important and how they can benefit your data onboarding processes:
Version control
Version control, often managed through tools like Git, is a systematic way of tracking changes to your scripts, configurations, and any other code-related assets. In the context of data onboarding, version control is essential for several reasons.
- Change Tracking: Version control allows you to keep a historical record of every change made to your data onboarding scripts. This includes modifications, additions, and deletions.
- Collaboration: If multiple team members are involved in managing data onboarding, version control enables collaborative work. Team members can work on separate branches, making changes without directly impacting the main codebase until they are ready.
- Error Tracking: In case an issue arises after a change is implemented, version control helps you identify the exact change that might have caused the problem. This speeds up the process of debugging and resolving issues.
- Reversion: If a change leads to unexpected results or issues, version control allows you to revert to a previous working version of the scripts. This is particularly helpful in quickly rolling back changes to maintain data integrity.
Auditing
Here's why auditing matters:
- Compliance: In regulated industries, auditing helps ensure that your data onboarding processes adhere to regulatory requirements. Having a record of changes and who made them is crucial for demonstrating compliance.
- Accountability: Auditing adds a layer of accountability. Knowing that changes are being tracked and reviewed can encourage responsible practices among team members.
- Root Cause Analysis: When an issue arises, auditing can help pinpoint the root cause. It allows you to trace back when and by whom a specific change was made, aiding in troubleshooting.
- Process Improvement: By analyzing the history of changes and their impact, you can identify areas for process improvement and optimize your data onboarding procedures over time.
Data quality monitoring involves consistently assessing the quality of the data you have onboarded into your system to ensure that it meets the desired standards.
Importance of data quality monitoring
Maintaining high-quality data is essential for making informed decisions, ensuring accurate analysis, and deriving meaningful insights. Poor-quality data can lead to erroneous conclusions, misguided strategies, and operational inefficiencies. Data quality monitoring helps to:
- Detect Inaccuracies: Data quality issues can range from missing values to inconsistencies and errors. Monitoring allows you to catch these issues before they affect downstream processes or negatively impact your analyses and decisions.
- Operational Efficiency: Addressing data quality issues promptly reduces the time and effort required to correct larger-scale problems later.
- Maintain Trust: Accurate and consistent data builds trust among users, stakeholders, and decision-makers who rely on the information provided by the data.
- Enhance Decision-Making: Reliable data leads to more accurate insights, enabling better decision-making and informed strategies.
- Compliance: In regulated industries, data quality is often a compliance requirement. Monitoring ensures that your data meets these standards.
Data quality monitoring process
- Define Metrics: Establish clear metrics and criteria that define what constitutes high-quality data for your organization. This could include accuracy, completeness, consistency, and timeliness.
- Set Up Monitoring: Implement tools, scripts, or solutions that regularly assess the data against the defined metrics. This could involve automated checks or manual reviews.
- Real-Time Alerts: Configure real-time alerts that notify you when data quality issues are detected. These alerts could be sent via email, dashboards, or integration with incident management systems.
- Anomaly Detection: Use anomaly detection techniques to identify data points that deviate significantly from the expected patterns. This can help you catch subtle issues that might not be immediately obvious.
- Root Cause Analysis: When issues are flagged, conduct root cause analysis to understand the underlying reasons for the data quality problems.
- Immediate Remediation: After issues are identified and their root causes determined, take immediate action to rectify the data. This could involve data cleansing, normalization, or re-onboarding.
- Continuous Improvement: Regularly review the data quality monitoring process itself. Are the metrics still relevant? Are new issues arising that need to be addressed?
Data quality monitoring is a proactive practice that ensures the integrity of your data. By establishing metrics, setting up monitoring processes, and promptly addressing issues, you can maintain accurate, consistent, and reliable data for your organization's decision-making and operational needs.
Documentation
Documenting the data onboarding process ensures transparency, consistency, and effective management of the entire data lifecycle. This documentation acts as a comprehensive guide that captures the various aspects of the data onboarding process, making it easier to understand, replicate, and improve over time.
Importance of documentation
- Consistency: Documenting the data onboarding process ensures that the same steps are followed consistently each time new data is brought into the system. This minimizes errors and discrepancies that can arise from variations in execution.
- Knowledge Transfer: When team members change or new members join, comprehensive documentation allows for a smooth transfer of knowledge, helping team members to quickly understand the process and follow best practices.
- Future Reference: Documentation serves as a reference for the future. If issues arise or improvements are needed, the documented process provides insights into how the onboarding was originally set up.
- Enhanced Collaboration: Documentation fosters collaboration among team members as they can easily share insights, suggest improvements, and work together more effectively.
- Continuous Improvement: Documented processes can be reviewed periodically, leading to refinements and enhancements. These improvements contribute to the overall efficiency of data onboarding.
- Reduced Dependency: Relying solely on individual expertise can create dependency on specific team members. Documentation reduces this dependency and empowers the entire team to execute the process effectively.
- Risk Mitigation: In case of issues or discrepancies, documentation serves as a valuable reference point to identify the root cause and find effective solutions.
Key elements of documentation
- Validation Rules: Clearly outline the rules and criteria used to validate the data during onboarding. This includes defining acceptable data formats, ranges, and any specific conditions.
- Transformation Logic: Document how the data is transformed from its source format to the desired target format. Include details about calculations, aggregations, and any data modifications.
- Enrichment Sources: Specify where and how additional context or information is added to the data. This could involve referencing external data sources, APIs, or business-specific logic.
- Workflow Sequence: Detail the sequence of steps in the onboarding process. This includes the order in which validation, transformation, and enrichment occur.
- Dependencies: If the onboarding process relies on external systems, tools, or scripts, document these dependencies to ensure that everyone is aware of the interconnected components.
- Parameters and Configurations: Document the parameters, settings, and configurations used during data onboarding. This ensures that these settings can be accurately replicated or adjusted as needed.
- Error Handling: Describe the strategies for handling errors or exceptions that might occur during the onboarding process. This could involve error logging, notifications, or automated retries.
By implementing these standardized data onboarding procedures, you establish a foundation of reliable and consistent data in your Splunk platform environment. This, in turn, supports accurate analysis, reporting, and decision-making, while adhering to data management and governance best practices.
Helpful resources
This article is part of the Splunk Outcome Path, Enhancing data management and governance. Click into that path to find more ways to ensure data consistency, privacy, accuracy, and compliance, ultimately boosting overall operational effectiveness.
In addition, these resources might help you implement the guidance provided in this article:
- Splunk Docs: Use the CIM to validate your data
- Splunk Docs: Use the CIM to normalize data at search time
- Splunk Docs: How data moves through Splunk deployments: The data pipeline
- Splunk Docs: Use the Field transformations page
- Splunk Blog: Data normalization explained: How To normalize data
- Splunk Blog: Introducing Edge Processor: Next gen data transformation
- Use Case Explorer: Data sources and normalization
