Monitoring and alerting for disaster recovery and business continuity
Being prepared for potential system failures, resource shortages, or network disruptions is crucial to ensure uninterrupted operations. In this section, we will explore how to set up monitoring and alerting in the Splunk platform to proactively detect potential issues, enabling timely response and mitigation to safeguard your disaster recovery and business continuity efforts.
  1. Define key metrics for monitoring
  2. Select appropriate data sources
  3. Create alerting rules
  4. Set up PICERL-based escalation procedures
  5. Test your monitoring and alerting set up
  6. Monitor performance and optimize
Before implementing monitoring and alerting, identify the critical metrics that need monitoring. Focus on system health (CPU, memory, disk space), network connectivity, and data replication status. Understanding your organization's specific needs will help you choose the right metrics to track and ensure proactive monitoring.
  1. Assess Critical Splunk Systems and Services: Start by assessing the critical systems: indexers, search heads, license managers, deployment server, services, and applications essential to your organization's Splunk deployment. This might include servers, networking equipment, cloud resources, and other critical services. Identify the dependencies between these components to understand their interconnectivity.
  2. Identify Potential Failure Points: After you clearly understand your critical systems, identify potential failure points or weak links that could lead to disruptions. For example, consider CPU and memory utilization, disk space availability, network latency, and data replication status. These metrics are crucial for detecting resource shortages or system failures.
  3. Determine Acceptable Thresholds: Establish acceptable thresholds for each metric. These thresholds define the limits beyond which a metric is considered abnormal or indicative of a potential issue. For example, you might set a threshold for CPU utilization at 80%, indicating that a sustained CPU usage above this level could be a cause for concern.
  4. Align Metrics with Business Objectives: Ensure that the chosen metrics align with your organization's business objectives and disaster recovery priorities. Focus on metrics that directly impact critical business processes, customer experience, and regulatory compliance. This alignment ensures that your monitoring efforts are targeted and impactful.
  5. Consider Historical Data and Trends: Analyze historical data to identify patterns and trends that might indicate potential issues. Understanding historical behavior helps in setting dynamic thresholds that adapt to changing usage patterns. For instance, you might notice that disk utilization tends to spike during specific time frames, and adjusting thresholds accordingly will prevent false alerts.
  6. Collaborate with Stakeholders: Involve key stakeholders, including IT teams, business owners, and disaster recovery experts, in the process of defining monitoring metrics. Gathering input from different perspectives will lead to a comprehensive and well-rounded monitoring strategy.
  7. Continuously Review and Update: Monitoring requirements evolve over time due to changes in technology, business processes, and external factors. Regularly review and update your monitoring metrics to stay aligned with the organization's changing needs.
Splunk offers various options for monitoring and setting up alerts across diverse data sources. Choose data sources that provide relevant information to monitor your disaster recovery and business continuity efforts effectively. Consider using built-in monitoring apps, along with relevant add-ons or custom data sources tailored to your requirements.
  • Splunk Indexer and Search Head Status: Monitor the availability and performance of your Splunk indexers and search heads. Check for any service disruptions or issues that could affect data indexing and search capabilities. Consider checking the health endpoint for Splunk service status from the cluster manager by using | rest /services/server/health-config.
  • License Usage: Keep track of your Splunk license usage, including daily indexing volume and the number of indexed events. Ensure that you do not exceed your licensed limits to prevent disruptions to data ingestion.
  • Disk Space Utilization: Monitor the disk space usage on all Splunk servers, particularly on indexers, to avoid data loss due to insufficient storage. Set up alerts for low disk space conditions to take timely action.
  • System Resource Utilization: Monitor CPU, memory, and network utilization on your Splunk servers. High resource usage can lead to performance degradation or even system crashes.
  • Indexing Performance: Track the rate at which data is being indexed and the time it takes for events to become searchable. Monitoring indexing performance helps identify bottlenecks and optimize data ingestion.
  • Search Performance: Monitor the response times of search queries. Slow searches can impact user experience and might indicate issues with system performance.
  • Forwarder Status: Monitor the health of Universal Forwarders to ensure that data collection from various sources is functioning correctly.
  • Splunk Internal Logs: Monitor internal Splunk logs, including logs related to licensing, indexing, and search activities. These logs provide valuable insights into the health of the Splunk platform itself.
  • Replication Status (for Distributed Environments): In distributed Splunk environments, monitor data replication across indexers and search heads to ensure data redundancy and high availability.
  • Splunk Web Interface: Regularly check the accessibility and performance of the Splunk Web interface to ensure users can access and interact with the platform without interruptions.
  • Health Check Dashboards: Leverage pre-built health check dashboards or design custom ones to consolidate the essential metrics mentioned earlier, using both the Monitoring Console and Cloud Monitoring Console. These dashboards offer a comprehensive overview of the overall health of the Splunk platform.
By monitoring these critical items in the Splunk platform, you can proactively identify and address any issues, optimize performance, and ensure the reliability and stability of your Splunk deployment. Regular monitoring and alerting enable quick responses to potential problems, contributing to the overall effectiveness of your Splunk environment.
Crafting well-defined alerting rules is essential for timely response to potential issues. Establish thresholds for each metric that, when breached, will trigger an alert. For instance, set alerts for disk space reaching a certain capacity or replication delays exceeding specific time frames. These rules will help you detect issues early and take appropriate actions swiftly. A good starting point is the built-in Monitoring Console, which you can learn about in Monitoring Splunk Enterprise overview.
PICERL is an acronym for a structured incident response process that encompasses six phases. These phases guide how organizations respond to and recover from security incidents. The stages are:
  1. Preparation: This involves setting up and maintaining an incident response capability. It includes establishing an incident response policy, setting up an incident response team (IRT), creating a set of guidelines for the IRT, and ensuring that all members are trained and equipped with the necessary tools and resources.
  2. Identification: This is the stage where potential security incidents are detected and acknowledged. Tools and systems can flag unusual activities, which then need to be analyzed to determine if they represent a genuine security incident.
  3. Containment: After an incident is identified, you must contain the damage. Containment is often divided into two phases:
    • Short-term Containment: Immediate actions to temporarily halt the threat (for example, disconnecting a compromised system from the network).
    • Long-term Containment: More permanent measures to ensure the threat does not spread or recur.
  4. Eradication: After containment, the root cause of the incident is found and completely removed from the environment. This could involve patching software, removing malicious code, or strengthening security measures.
  5. Recovery: This stage is about restoring and validating system functionality for business operations to resume. It might involve restoring systems from backups, validating the integrity of system data, or ensuring that systems are free from any remnants of threats.
  6. Lessons Learned: After handling the incident, teams review the incident, the effectiveness of the response, and the lessons learned. This review helps improve the incident response process for future incidents. Feedback from this phase might loop back to the preparation phase to refine and improve procedures and training.
Organizations that adopt the PICERL model are better prepared to handle incidents systematically, ensuring they are both reactive to current threats and proactive in preventing future incidents. Utilizing the PICERL response methodology for alerts in the Splunk platform ensures a systematic approach to handling and mitigating threats in real-time.
Here's a breakdown of how PICERL can be integrated into your Splunk environment:
Preparation
  • Define Alert Severity Levels: Categorize alerts into severity levels like "Critical," "Warning," and "Informational," each with distinct criteria. This step provides clarity on conditions that trigger each alert.
  • Establish Roles and Responsibilities: Assign key personnel to specific roles like "Initial Responder", "Incident Manager", or "Forensic Analyst". Detail each role's responsibilities.
Identification
  • Automate Alert Routing: If possible, automate the alert routing process to ensure alerts are delivered to the appropriate personnel automatically. Use tools like email notifications, messaging platforms, or ticketing systems to route alerts to the designated recipients based on their roles.
  • Set Response Time Targets: Determine the maximum allowable time for acknowledging and responding to alerts at each severity level. For example, "Critical" alerts might require an immediate response within minutes, while "Warning" alerts might have a response time target of a few hours.
Containment
  • Design the Containment Strategy: Develop strategies for both short-term and long-term containment of threats identified by the alerts.
  • Design the Escalation Flow: Create a step-by-step flowchart or documentation that outlines the escalation process. Define the sequence of actions to be taken when an alert is triggered, including the contact details of personnel at each escalation level.
  • Implement Escalation Hierarchies: In case an alert remains unaddressed at one level, establish escalation hierarchies to ensure it gets escalated to the next level of expertise. For instance, if a "Critical" alert is not acknowledged within a certain timeframe, it should automatically escalate to higher-level engineers or managers.
Eradication
  • Determine Root Causes: Analyze alerts to identify the root causes and take steps to remove the source of the threats.
Recovery
  • Monitor Environment Post-Eradication: After addressing the alert, continue monitoring to ensure the Splunk environment returns to its normal state.
  • Validate the Alert Clearance: Perform checks to ensure that threats have been fully eradicated before moving systems back to regular operations.
Lessons Learned
  • Test the Escalation Procedures: Conduct mock drills and tests of the escalation process to validate its effectiveness. Simulate different alert scenarios and ensure that alerts are correctly routed, and the response times are met.
  • Document and Communicate the Procedures: Document the entire escalation process along with contact details and response time targets. Share this documentation with all relevant team members and stakeholders to ensure everyone is aware of the procedures.
  • Regularly Review and Improve: Periodically review the escalation procedures and analyze past incidents to identify any gaps or areas for improvement. Adjust the procedures based on feedback and lessons learned to optimize the response process continually.
By setting up well-defined PICERL-based escalation procedures, Splunk users can ensure that critical alerts are promptly addressed by the appropriate personnel. This approach minimizes response delays, reduces downtime, and contributes to a more effective disaster recovery and business continuity strategy.
Test your monitoring and alerting setup
Conduct mock disaster recovery drills and test scenarios to simulate potential issues. Evaluate how your system responds to alerts and fine tune the setup if necessary. Here's a detailed procedure for testing your alerting setup in the Splunk platform:
  1. Test Alert Conditions: Verify that your alert conditions are set correctly and capture the desired events. Run test queries or searches against sample data to ensure that the alert conditions accurately match the events you want to monitor.
  2. Use Test Data: Create test data or use synthetic events that mimic real-world scenarios. This allows you to trigger alerts without impacting your production data or systems. Ensure that the test data includes a mix of scenarios covering different severity levels.
  3. Disable Real Notifications: Before starting the testing, disable any real notifications or actions that could be triggered by the alerts. This prevents unnecessary escalations or actions during the testing phase.
  4. Trigger Test Alerts: After you have your test data and disabled real notifications, manually trigger the test alerts. This can be done by generating events that match the alert conditions you've set up.
  5. Verify Alert Triggering: Check the Splunk system to confirm that the test alerts were triggered correctly. Validate that the triggered alerts are appearing in the Splunk interface and are listed as triggered in the alert management section.
  6. Review Alert Content: Examine the details of the triggered alerts to ensure that the information included in the alerts is relevant and provides sufficient context for further investigation.
  7. Check Notifications: If you have configured email or other notification methods, verify that the alerts are being sent to the designated recipients. Confirm that the notification content is clear and includes essential information for immediate action.
  8. Test Escalation: If your alerting setup includes escalation procedures, simulate scenarios where alerts should escalate to higher-level personnel. Verify that the escalation process functions as intended and that alerts reach the appropriate individuals within the defined response time targets.
  9. Assess Response Actions: If the alerting setup triggers any automated response actions, such as restarting services or running scripts, evaluate whether these actions run correctly and have the outcome you want.
  10. Review Logs and Reports: Analyze the logs and reports generated during the testing to identify any errors or issues. Address any problems and make necessary adjustments to the alerting configurations.
  11. Document the Results: Document the results of the testing, including the alerts triggered, notifications sent, and any issues identified. Use this documentation to make improvements and adjustments to your alerting setup.
After implementing the monitoring and alerting system, continuously monitor its performance and effectiveness. Regularly review the alerting rules and adjust them based on changing business needs and evolving IT environments. Optimize your setup to ensure it remains relevant and efficient. Here's a detailed explanation of monitoring performance and optimizing the setup:
  • Continuous Monitoring: Regularly monitor the alerting system to ensure it is operational and capturing events as expected. Keep track of the number of alerts triggered, their frequency, and their severity levels. Monitoring helps you identify any irregularities or potential issues with the alerting rules and system.
  • Performance Metrics: Define and track key performance metrics for your alerting setup. Measure the time taken for alerts to trigger, the time taken for notifications to be sent, and the time taken for responses to occur. Performance metrics provide insights into the responsiveness and efficiency of the alerting system.
  • Review Alerting Rules: Conduct periodic reviews of the alerting rules to assess their relevance and effectiveness. Ensure that the alert conditions still align with your business needs and IT environment. Remove or update rules that are no longer necessary or are producing excessive false positives.
  • Business Needs Alignment: Align the alerting system with changing business needs and goals. Work closely with stakeholders to understand their evolving requirements and adjust the alerting rules accordingly. This ensures that the monitoring focuses on critical areas that align with business objectives.
  • IT Environment Changes: Stay aware of any changes in your IT environment, such as infrastructure updates, software upgrades, or changes in data sources. Ensure that the alerting system adapts to these changes to continue providing relevant and accurate alerts.
  • Optimization Strategies: Implement optimization strategies to improve the efficiency and effectiveness of the alerting setup. This might involve refining search queries, adjusting threshold levels, or employing statistical models to reduce false positives.
  • Automated Responses: Explore opportunities to automate response actions for certain alerts. Automating responses can lead to faster mitigation of issues, reducing manual intervention and minimizing downtime.
  • Performance Tuning: Optimize the performance of your monitoring and alerting system by tuning hardware resources, such as memory and CPU, to handle increasing data volumes and maintain responsiveness.
  • Capacity Planning: Perform capacity planning to ensure that the monitoring infrastructure can handle future growth in data and events. Anticipate resource requirements and scale the system accordingly.
  • Continuous Improvement: Maintain a culture of continuous improvement for your monitoring and alerting setup. Encourage feedback from users and stakeholders to identify areas for enhancement and implement iterative improvements.
  • Security Considerations: Regularly review the security measures of the monitoring system to ensure that sensitive data and configurations are protected from unauthorized access.
  • Training and Education: Provide training and education to the team responsible for managing the alerting system. Ensure they are equipped with the knowledge and skills to optimize and troubleshoot the setup effectively.
By continuously monitoring and optimizing your alerting system, you can proactively address issues, ensure its alignment with changing requirements, and maintain its efficiency and relevance over time. This approach enhances the overall reliability of your disaster recovery and business continuity strategies, allowing for timely responses to potential issues and minimizing downtime.
Additional resources
This article is part of the Splunk Outcome Path, Establishing disaster recovery and business continuity. Click into that path to continue building a plan for catastrophic failures to ensure a smooth recovery process.
In addition, these resources might help you implement the guidance provided in this article:
