Using inputlookup and lookup commands correctly
You might have seen the inputlookup and lookup commands used in searches and wondered how they are different. If you use Splunk Answers for information on the commands, you might find that some of your peers confuse them. They are not interchangeable. This article clarifies the difference.
inputlookup
This command loads the entire contents of a lookup table into the results set. You can use the where option to limit the rows read.
It is a generating command, but it can be used as a streaming command with the append option.
Use case
If you store asset information in a lookup file, you can use inputlookup to read the file for further processing in SPL. For example, you might want to know how many servers are running Windows 2016.
| inputlookup assets.csv WHERE os=”Windows 2016” | stats count
You can also use this command in a subsearch to filter data. This query searches the “foo” index for events where the “country” field contains the name of a country in North America.
index=foo [|inputlookup geo_attr_countries WHERE continent="North America" |fields country]
Examples
|inputlookup geo_attr_countries WHERE country=Canada
lookup
This command enriches a results set by adding new fields based on the values of one or more existing fields. For instance, you might want to associate an employee name to their email address or a host name with its location.
It is a streaming command.
Use case
- Map a country name to an abbreviation using a built-in lookup file
|lookup geo_attr_countries country OUTPUT iso2
- Map an email address to an employee name
|lookup employee.csv email_addr OUTPUT name
- Resolve an IP address
|lookup dnslookup clientip AS src_ip
- Get a host’s location
|lookup assets.csv host OUTPUT location
Examples
|eval country="Canada" |lookup geo_attr_countries country
|eval continent="North America" |lookup geo_attr_countries continent
- Splunk Help: inputlookup command
- Splunk Help: lookup command
- Splunk Help: streaming command
- Splunk Help: generating command
