Scaling Edge Processor infrastructure
In this series we’ll be looking at scaling Splunk Edge Processor using Amazon EKS, as well as some steps to get us there. There are a number of factors that can affect the required scale of your Splunk Edge Processor infrastructure, including:
  • Changes to data volumes
  • Implementation or retirement of use cases
  • Increasing or decreasing pipeline complexity
All of these are very common scenarios that require Edge Processor scale to be adaptable, and in this first article we’ll explore scaling concepts.
How does Edge Processor scale?
As your data processing requirements change, you’ll have to decide whether to scale by altering the available resources for your Edge Processor nodes, or by altering the number of nodes doing the processing.
Let’s take a look at some scenario examples that can lead to different scaling outcomes. As is the case with most technology, Edge Processor nodes scale both vertically and horizontally, depending on the observed behavior.
Scenario Example Scale Example
Scale up (vertical)
  • Number of forwarders or TCP connections increases
  • Data pipeline complexity increases, such as:
    • More complex regular expressions
    • Multi-value evals and mvexpand
    • More destinations
  • Significant event size or event volume increases
  • Long persistent queue requirements
Example scale scenario
From
To
Scale out (horizontal)
  • Need to improve indexer event distribution (avoid funneling)
  • Spread out persistent queues
  • Improve resiliency, reduce impact of node failure
From
To
For most purposes we’ll consider any substantial change to any of the following as cause to evaluate our scale:
  • Event volume, both number and size of events
  • Number of agents
  • Number and complexity of pipelines
  • Change in target destinations
  • Risk tolerance
Any change to these factors will play a role in the overall resource consumption and processing speed of your Edge Processor nodes.
How do I know when it’s time to scale?
Because Edge Processor nodes run on your infrastructure, you are responsible for managing changes in scale. With the telemetry reporting built into Edge Processor, you can monitor and adapt to resource utilization reported by the Edge Processor nodes. This could result in manually adjusting scale, executing automation frameworks, invoking cloud workflows, or, as we’ll explore in this series, using containers and Kubernetes to scale to demand.
  • Your first stop should be the Ingest Monitoring app and dashboards. These will provide you with a lot of detailed context on pipelines and data performance.
  • When you are ready to get into the weeds, you can explore all of the metrics using mcatalog:  | mcatalog values(metric_name) WHERE index=_metrics AND sourcetype="edge-metrics"
There’s no one metric that can tell you it’s time to scale up or down, instead we suggest watching some key metrics across your edge processors in order to establish baseline, expected usage metrics. In particular:
  • GB in/out per day
  • Event counts in/out per day
  • Exporter queue size
  • CPU & memory consumption
  • Unique source types and agents per day
Additionally, consider measuring event lag by comparing index time versus event time as a general practice for GDI health, irrespective of Edge Processor.
As you prepare for or encounter scaling events, you can use these common metrics to help determine the effectiveness of your scale operation. As a general rule, we recommend scaling once CPU or memory reaches and sustains 70% utilization during normal operations.
Scaling up (vertical)
As CPU and memory become overutilized due to changes in data processing, often the most straightforward approach to scaling is to add more of those constrained resources. Supporting metrics such as data rates, queue size, number of source types, and agent counts will often indicate that the core resources of CPU and memory are likely to become constrained, but the best indicator for deciding when to allocate or deallocate those resources are the measurements of the core resources themselves. As CPU or memory approach 80% or more, use the supporting metrics to determine whether additional resources will properly address the situation. You can use the magnitude increases of the supporting metrics to help inform your resource allocation estimates.
As shown in the scale examples in the table above, adding more CPU and memory resources is the most common approach when pipeline complexity and event load increases. This organic, gradual growth is the most likely scenario that will happen over time as use of the platform increases. However, at some point you will see diminishing returns on vertical growth, whether due to CPU parallelism constraints, infrastructure limitations, increased risk due to failure, or just practical/internal hardware provisioning guidelines. As you reach vertical limitations, or as your situation aligns better to horizontal scaling, it’s probably time to consider adding more nodes rather than just making bigger nodes.
Vertical scaling relies on a sufficient number of TCP connections. If you are seeing diminishing returns when adding CPU, consider increasing the number of upstream channels and connections.
Pros
  • Generally very easy to do in virtualized or containerized environments
  • Fewer nodes to manage
  • No need to provision or maintain new hardware
  • Most common solution
  • Easy to see results
Cons
  • Puts more data at risk due to node failure
  • Infrastructure will likely have maximum allowable sizes
  • Diminishing returns above 6 CPU cores (as of this writing)
  • Additional resource cost
Scaling out (horizontal)
Vertically scaling the hardware resources for a given workload on a given node is the most important, and is typically the first step in scaling, but as your utilization increases beyond your chosen vertical scale and as you look to address other scaling challenges it’s time to scale out. Scaling out Edge Processor is the process of provisioning additional nodes that are associated with a given Edge Processor. Remember, Edge Processors are the logical grouping of configuration settings, and Edge Processors have one or more nodes assigned to them. Just as you provisioned your first Edge Processor node by using the Manage Instances screen, you will use that same screen to add more nodes.
As shown in the scale examples in the table above, the primary considerations for scaling out are a bit different than when scaling up. Just like Splunk indexers and intermediate forwarders, with Edge Processors, you will generally look at horizontal scaling to support other horizontally-focused growth like supporting a significantly large number of forwarders, reducing data loss risk, and providing a wider funnel for event distribution. The great part of horizontal scaling is that more nodes will generally achieve these resiliency-focused goals as well as reducing resource constraints on a per node basis.
Pros
  • Reduce per node resource constraints
  • Reduce per node data loss risk
  • Can improve event distribution
  • Increase workload within vertical scaling constraints
Cons
  • More nodes to manage
  • Time spent onboarding new instances
  • Managing firewall and network routing rules
  • Additional cost
As you can see, the primary challenge with horizontal scaling is that it’s more infrastructure to manage, which also means more administrative time for onboarding and offboarding these instances as your requirements change. This can in turn lead to change management database (CMDB) churn, more reliance on other teams, additional troubleshooting, and other common infrastructure-related toil.
This series is meant to help alleviate these horizontal scaling challenges and provide a fast on-ramp for growing your Edge Processor footprint in a rapid and easily supported way. The first step is understanding the authentication requirements for automatically provisioning Edge Processor instances and preparing your environment.
