Migrating from intermediate forwarders to Edge Processor
As organizations evolve their data management strategies, a common question arises: Can existing intermediate Splunk Heavy Forwarders be replaced with Splunk Edge Processor?
This guide provides comprehensive context, common scenarios, and key considerations to help you evaluate whether migrating to Edge Processor is right for your environment. It is important to understand that individual environments are frequently nuanced, and there might be several different implementations and requirements across different intermediate deployments within the same organization. Any migration should be carefully considered, and guidance from Splunk On-Demand Services, Splunk Professional Services, or Splunk Architects should be leveraged to properly scope and plan your migration.
Splunk is in the process of mitigating many of the risks and challenges discussed in this article.
Understanding the benefits and considerations
Before embarking on a migration, it's essential to understand both the key motivators and potential challenges associated with moving from intermediate forwarders to Edge Processor.
Key motivators for Edge Processor migration
| Motivation | Description |
| Centralized configuration management | Manage all pipeline configurations from a single, centralized location rather than distributing configurations across multiple forwarders. |
| Authoring rules in SPL2 | Leverage the power and flexibility of SPL2 for creating transformation rules and pipelines. |
| Improved efficiency | Better scaling of event processing for similar hardware resources, allowing you to do more with your existing infrastructure. |
| Advanced transformation capabilities | SPL2 provides the ability to run more complex transformations than traditional props/transforms configurations. |
| UI-based management | Entirely UI-based configuration and management, which is beneficial for people who prefer visual interfaces over configuration file management. |
Key considerations before migration
| Consideration | Description |
| Timestamping and parsing relocation | In many cases, timestamping logic will move to the indexing tier, which represents a fundamental change in how events are processed. Additionally, transforms that might otherwise have been ignored on the indexers might begin being processed. Detailed props and transforms review is required. Read more here. |
| Increasing indexer workload | Moving parsing to the indexers can increase SVC/indexer workload for indexing pipeline and index-time field extractions. |
| Source type handling | You will need to operate on original source types, which might be different than indexed and search-time source types that your organization is accustomed to working with. |
| Learning curve | New language (SPL2) and product architecture to learn, which requires investment in training and ramp-up time. |
| UI-based management | While beneficial for some people, the entirely UI-based approach might be less preferred by administrators who are comfortable with configuration file management. |
| Differences in data resilience | useAck, persistent queues, and full queue have different behavior on each platform. |
| Cost | Like Heavy Forwarders, Edge Processors have no licensing cost or usage limitations. |
Migration discovery: Evaluating your environment
The following questions and considerations should be used to understand your scenario and help qualify a Splunk Edge Processor migration. The considerations listed are provided to provide context to the questions, not to fully qualify the outcome. Edge Processor migrations from Universal Forwarders and heavy forwarders are nuanced, and the decision of whether to migrate will likely be weighed against the outcomes of these questions as a whole. In some cases, the answers to these questions can rule out a migration entirely, but more often the answers shape the migration.
Understanding your motivation
Question: What is your motivation for implementing Edge Processor or Ingest Processor?
Considerations:
- Are you looking to reduce data ingest volumes?
- Is easing management overhead a primary driver?
- Do you need to transform events in ways that are difficult with current tools?
- Are there specific functionalities found in SPL2 that you want to leverage?
Understanding your core motivation will help determine whether Edge Processor is the right solution and will shape the migration approach.
Evaluating current heavy forwarder functionality
Question: How are your heavy forwarders currently configured and used?
Considerations:
Heavy forwarders with or without the use of Ingest Actions can perform a great deal of transformation and routing, including filtering and masking through the use of props and transforms.
- Are they primarily used for network funneling?
- Are they performing event parsing? Line breaking, and timestamping?
- Are they running mod_inputs TAs?
- Are they offloading parsing from the indexers?
- How many intermediate forwarder deployments are there?
- Which data sources are going to which intermediate deployment? How many EPS? Which source types? How much volume?
Understanding the full scope of what your heavy forwarders are doing today is critical to planning a successful migration.
Determining Splunk Edge Processor implementation feasibility
Question: Are your heavy forwarders acting as data collection nodes?
Considerations:
- It’s sometimes the case that data collection workloads (mod_inputs) run on the same servers as intermediate routing and forwarding workloads.
- Edge Processor does not support the role of a data collection node (DCN).
- As a best practice, heavy forwarders should not run mixed workloads like this, but many environments have evolved this way over time.
- If your heavy forwarders are performing data collection, these functions will need to be separated before or during migration.
Edge Processor does not do traditional parsing of events from Universal Forwarders. The parsing operation moves downstream to the next splunkd pipeline, usually to the indexing tier.
Considering Splunk Ingest Processor as an alternative
Question: Can Ingest Processor be used in addition to heavy forwarders for advanced data processing?
Considerations:
- Ingest Processor can be used within Splunk Cloud Platform Victoria to perform processing of events while retaining upstream heavy forwarders for initial parsing.
- Ingest Processor offers hosted Edge Processor functionality without changing heavy forwarder configurations.
- This enables advanced data processing prior to indexing.
- Retaining heavy forwarder infrastructure and moving parsing to Ingest Processor can simplify and reduce heavy forwarder operations while adding or maintaining transformations without additional infrastructure.
Assessing architecture complexity
Question: Does adding Edge Processor simplify your architecture or add unnecessary complexity?
Considerations:
- Wholesale replacement of heavy forwarders with Edge Processor would, in most cases, introduce significant complexity.
- Universal Forwarder-based data passing through the intermediate tier requires immediate remediation to avoid incorrect indexer parsing (see the Remediation Details section below).
- There would have to be considerable benefit of using Edge Processor versus heavy forwarders to justify a 1:1 replacement.
- Evaluate whether the benefits outweigh the migration effort and potential risks.
Evaluating incremental transition options
Question: Is an incremental transition possible?
Considerations:
- If additional hardware can be provisioned, placing Edge Processor in-between the existing heavy forwarder tier and the destination can ease the migration burden. This approach keeps parsing at the Heavy Forwarder while enabling Edge Processor to further transform events.
- Over time, the line breaking logic can be migrated to either Edge Processor or the destination as appropriate.
Incremental migration path
| Phase | Routing | Processing |
| Initial | UF -> HF -> Index | All parsing and transformation done on HF. |
| Intermediate | UF -> HF -> EP -> Index |
Line breaking and timestamping done at HF. Transformation and routing done at EP. |
| Target | UF -> EP -> Index |
Line breaking and transformation done on EP. Indexer can optionally run TA transformations. |
Identifying advanced processing needs
Question: Are there advanced processing needs that Edge Processor or Ingest Processor can fulfill better than heavy forwarders can?
Considerations:
- Edge Processor/Ingest Processor and the use of SPL2 can more easily address "advanced" processing such as:
- Schema transformation
- Lookups
- Multiple routes
- Logs to metrics conversion
- Stats
- For small changes like basic filtering and masking, heavy forwarders are fully capable of performing these functions.
- Consider whether your processing needs justify the migration effort.
Making the final decision
Action: Collaborate with Splunk On-Demand Services, Solutions Architects, Theater Architects, and Professional Services to assess the level of effort for integrating Edge Processor or Ingest Processor.
Question: Based on the above evaluations, is Edge Processor or Ingest Processor integration the best path forward?
Considerations:
- Weigh all pros and cons identified through the discovery process.
- Factor in additional Edge Processor infrastructure requirements.
- Consider additional licensing cost of Ingest Processor for volumes exceeding 500 GB/day.
- Evaluate the total cost of ownership including migration effort, training, and ongoing operations.
Important note on routing protocols
The following guidance is specific to routing data to the Splunk platform. It is also assumed that forwarders and Edge Processor will be using Splunk protocol (s2s) to send that data.
Alternative protocols not covered in this guide:
- Splunk forwarders have the ability to send data to Splunk through s2s over HTTP (httpout).
- Edge Processor has the ability to send data to Splunk through HTTP Event Collector (HEC).
Using httpout or HEC can change the outcomes described in this guide dramatically and are not covered by this guide. Similarly, routing to other destinations (TCP, syslog, S3, NFS) are not covered by this guide.
Common migration scenarios
The following guidance details the most common intermediate routing architectures and provides context and high-level migration steps that will likely be encountered as part of a migration. In practice, there are many bespoke configurations that might not be represented below. This guide is not a runbook, and additional architectural and planning guidance will be needed for production migrations. You should almost always engage with your account team and Splunk On-Demand or Professional Services for migration guidance.
Scenario 1: Universal forwarder intermediate routing tier
Click here for details
Architecture: UF > IUF > Splunk platform
Current implementation details
Role of intermediate forwarder (IUF)
- Lightweight, low-touch aggregation layer
- Network firewall rule simplification
- Can be used to simplify certificate management
Common configuration details
- Splunk Cloud Platform Universal Forwarder package (certificates, server names)
- Possibly non-default parallel pipelines configured for throughput
Infrastructure notes
- Funneling precautions usually in place (except Victoria)
- Typically follows a 2:1 forwarder to indexer ratio
Parsing role
- Universal Forwarders usually do no parsing except in some rare configurations
- Universal Forwarder events usually remain unparsed
- Strictly passthrough in most cases
- Indexer carries parsing burden
Configuration warnings
- Sometimes event breaking and parsing is configured on the Universal Forwarder and should be considered during a migration.
- Review all inputs.conf and props.conf configurations on intermediate Universal Forwarders.
Edge Processor migration details
Migration complexity
Low - This is the easiest of replacement scenarios.
Key migration points
- If using as a pure passthrough/aggregation layer, the Edge Processor default pipeline and default configuration is acceptable.
- The Splunk Cloud Platform Universal Forwarder package is used to configure Edge Processor by default.
- Minimal configuration changes are typically required.
Pre-migration checklist
- Verify that intermediate Universal Forwarders are not performing any parsing.
- Review inputs.conf for any custom configurations.
- Review props.conf for any event breaking rules.
- Confirm network connectivity requirements for Edge Processor.
- Plan for certificate management transition.
Scenario 2: Heavy forwarder Splunk intermediate routing tier
Architecture: UF > IHF > Splunk platform
Role of intermediate forwarder (IHF)
- Aggregation tier for consolidating data from multiple Universal Forwarders
- Offload technology add-on (TA) workload from indexers
- TAs usually installed on heavy forwarders
- Time or volume-based load balancing usually configured
- Acknowledgment (ACK) can be configured on both input and output
- Significantly more hardware required than Universal Forwarder intermediate tier
- Parallel pipelines often in use to take advantage of more powerful hardware
Parsing role
- Events change from unparsed to parsed as they pass through the heavy forwarder
- Props/transforms and rulesets (Ingest Actions) can be used here
- This is often where significant data transformation occurs
Moderate to high
Key migration steps
- Scope configuration migration:
- Determine which configurations and/or TAs will move to the indexing tier.
- Identify which configurations will become Edge Processor pipelines.
- Document all current props/transforms configurations.
- Technology add-on migration:
- For Splunkbase/supported TAs, consider migrating the TA to Splunk Cloud Platform.
- Verify TA compatibility with your Splunk Cloud Platform version.
- Test TA functionality after migration.
- Custom configuration migration:
- For bespoke props/transforms, consider writing an Edge Processor pipeline.
- Translate transformation logic to SPL2.
- Test pipeline functionality thoroughly.
- Line breaking configuration:
- Any source types routed through heavy forwarders must have Edge Processor line breaking defined.
- Review all source types currently processed by heavy forwarders.
- Create corresponding line breaking rules in Edge Processor.
- Understand parsing changes:
- Timestamping and line breaking moves to the indexing tier.
- Events remain unparsed through Edge Processor.
Critical considerations
| Consideration | Impact |
| Dormant transforms activation | Events passing through Heavy Forwarders become parsed, which means indexer TAs that use transforms don't have any effect on those events. Events that pass through Edge Processor will remain unparsed, so those "dormant" transforms may unexpectedly become active at the indexer layer. This can cause unexpected behavior and must be carefully evaluated. |
| Load balancing limitations | Edge Processor only supports time-based load balancing. If you are currently using volume-based load balancing, you might need to adjust your approach. |
| Acknowledgement not supported | Edge Processor does not support ACK on Splunk connections. If you rely on acknowledgment for data integrity verification, alternative approaches need to be considered. |
| Line breaking limitations | Edge Processor does not support every line breaking configuration available on heavy forwarders. Review your current line breaking rules for compatibility. |
- Inventory all TAs installed on heavy forwarders.
- Document all props.conf configurations.
- Document all transforms.conf configurations.
- Identify all Ingest Actions rulesets.
- List all source types processed by heavy forwarders.
- Identify any volume-based load balancing configurations.
- Document ACK configurations.
- Review indexer-side transforms for potential activation.
Scenario 3: Heavy forwarder HEC routing tier
Architecture: HEC > Load Balancer > HF > Splunk platform
- Provide dedicated HEC processing endpoint
- Centralized HEC token management
- For more than one Heavy Forwarder, a third-party load balancer is generally used to consolidate connections
- Load balancer health checks configured against Heavy Forwarder HEC endpoints
Parsing role
- HEC events are always parsed when received
- HEC tokens behave differently between heavy forwarders and Edge Processor
- This difference is critical and must be understood before migration
Moderate to high
Key migration steps
- Review HEC token behavior:
- Carefully review Edge Processor HEC token behavior.
- Understand the differences from heavy forwarder token behavior.
- Plan for token migration or re-creation.
- Resource planning:
- Ensure sufficient Edge Processor resources to meet HEC connection needs.
- HEC workloads can be connection-intensive.
- Plan for peak load scenarios.
- Load balancer configuration:
- An external load balancer is almost always required for both heavy forwarders and Edge Processor when HEC is used.
- However, the configuration of that load balancer, especially service health checks, depends on Edge Processor token configuration.
Critical load balancer consideration
When tokens are enabled on Edge Processor, the HEC health endpoint must be retrieved with a valid HEC token. Not all load balancers can do this. Before migration, verify that your load balancer supports:
- Passing authentication tokens in health check requests
- Custom header configuration for health checks
- Token-based health endpoint validation
- Document all HEC tokens and their configurations.
- Review Edge Processor HEC token documentation.
- Assess Edge Processor resource requirements for HEC load.
- Verify load balancer capabilities for token-based health checks.
- Plan load balancer configuration changes.
- Test health check configuration in non-production environment.
Scenario 4: Heavy forwarder syslog collection and routing tier
Architecture: Syslog > IHF > Splunk platform
Refer to the Edge Processor Validated Architecture: Syslog for further details on syslog collection best practices.
This section is specific to scenarios where the heavy forwarder is the syslog listener. For scenarios where syslog is collected by SC4S, syslog-ng, or other syslog tools, refer to Scenario 2 (Heavy Forwarder Splunk Intermediate Routing Tier) since the protocol/architecture will be Splunk (s2s) or HEC.
- Acting as the syslog listener and initial collection point of syslog network traffic (TCP/UDP)
- First point of data ingestion for syslog sources
- One or more network port listeners configured
- Initial sourcetyping and metadata assignment usually performed with TAs
- Props/transforms for event parsing and field extraction
- Load balancing strategy for heavy forwarder syslog listeners will likely be the same for Edge Processor listeners
- Consider network topology and firewall rules
Parsing role
- Initial index, source, and source type set by input and props configurations
- Line breaking defined by props/transforms
- Heavy forwarders commonly perform significant parsing of syslog events
- Heavy forwarders are Syslog RFC agnostic, whereas RFC/Port alignment in Edge Processor is crucial
- Event host metadata logic is different between heavy forwarders and Edge Processor
High. As with the other scenarios above (and perhaps even more commonly), Heavy forwarders tend to do a lot of parsing of syslog events via props/transforms. Careful review of each heavy forwarder syslog input is required to properly migrate to Edge Processor. This can be a significant effort.
High
- Inventory syslog inputs:
- Document all syslog ports and protocols currently in use.
- Identify the RFC format of each syslog source.
- Map sourcetypes to syslog inputs.
- RFC alignment:
- Edge Processor syslog ports need to align to source RFC.
- Reconfiguration of upstream syslog sources/ports might need to be modified to be compatible with Edge Processor.
Incorrect RFC assignment in Edge Processor will result in invalid event metadata.
- Evaluate encrypted transport requirements:
- Heavy forwarders support syslog over TLS without mutual TLS (mTLS).
- Edge Processor only supports mTLS, which is not widely supported by syslog sources.
- This limitation might prevent some sources from directly migrating to Edge Processor.
- Host Metadata Remediation:
- Ensure host metadata resulting from heavy forwarder processing matches Edge Processor processing.
- The logic used to derive the host between heavy forwarders and Edge Processor is different.
- This will very likely need remediation to maintain consistency.
- Props/Transforms Review:
- Carefully review each heavy forwarder syslog input configuration.
- Translate parsing logic to Edge Processor pipelines.
- Test thoroughly to ensure event fidelity.
| RFC alignment | Edge Processor requires explicit RFC configuration per port. Misalignment causes metadata corruption. |
| mTLS requirement | Many syslog sources do not support mTLS, potentially blocking direct migration for encrypted transport. |
| Host metadata differences | Host field derivation logic differs significantly and requires explicit remediation. |
| Parsing complexity | Syslog parsing configurations are often complex and require careful translation to SPL2. |
- Inventory all syslog inputs (ports, protocols, source counts).
- Document RFC format for each syslog source.
- Identify sources using encrypted transport (TLS).
- Verify mTLS support for encrypted syslog sources.
- Document current host metadata derivation logic.
- Document all props.conf configurations for syslog source types.
- Document all transforms.conf configurations for syslog source types.
- Plan for sources that cannot migrate due to mTLS limitations.
Remediation details
Understanding why remediation is necessary is critical to planning a successful migration.
Why remediation is required
Splunk Edge Processor does not parse events in the same way that heavy forwarders parse events. Unparsed data that is sent to heavy forwarders undergoes line breaking and timestamping, whereas only linebreaking is performed in Edge Processor. Notably, Edge Processor does not set events to parsed/cooked as heavy forwarders do.
If heavy forwarders are removed from the existing processing flow, then the burden of parsing has to be handled by the downstream Splunk environment, which in many cases is not configured or prepared to handle that by default.
What remediation involves
| Remediation task | Description |
| Source type migration | Source types and TAs that are defined on the heavy forwarders have to be migrated to Splunk Cloud Platform in most cases. |
| Line breaking rules | In most cases, the line breaking rules for those source types also have to be configured in Edge Processor. |
| Individual evaluation | An evaluation of each source type has to be made and individually remediated before a wholesale replacement can be made. |
Remediation complexity assessment
While remediation may not be overly complex for any single source type, the cumulative effort across all source types can be significant. Consider:
- Total number of source types processed by heavy forwarders
- Complexity of props/transforms configurations per source type
- Custom versus Splunkbase TA configurations
- Testing requirements for each source type
Recommended approach
This is why an intermediate topology of UF → HF → EP → Splunk platform should be considered to ease the transition. The intermediate topology allows you to:
- Maintain existing parsing on heavy forwarders.
- Add Edge Processor transformations incrementally.
- Migrate line breaking rules to Edge Processor over time.
- Validate each change before proceeding.
- Roll back specific changes if issues arise.
Alternative: Splunk Ingest Processor
If you prefer to retain your existing heavy forwarder infrastructure or want to add advanced processing capabilities without significant architectural changes, Ingest Processor might be an appropriate solution.
Ingest Processor benefits
- Provides hosted Edge Processor functionality within Splunk Cloud Victoria
- Does not require changes to existing Heavy Forwarder configurations
- Enables advanced data processing prior to indexing
- Simplifies and reduces heavy forwarder operational overhead
- Adds or maintains transformations without additional on-premises infrastructure
Ingest Processor considerations
- Available within most Splunk Cloud Platform Victoria environments
- Licensing considerations apply for volumes exceeding 500 GB/day
When to consider Ingest Processor
- You want to retain existing heavy forwarder infrastructure
- You need advanced processing capabilities quickly
- You want to reduce heavy forwarder complexity without full migration
- Your environment is on Splunk platform Victoria
- You value less overhead/maintenance over more control over your environment.
Comparing options: Heavy forwarder, Splunk Edge Processor, and Splunk Ingest Processor
When evaluating alternatives, you might also be considering third-party solutions. The following guidance can help you compare options.
| Capability | Heavy forwarder | Edge Processor | Ingest Processor |
| Parsing | Yes | Limited | Yes |
| Transformation | Limited | Yes | Yes |
| Filtering | Yes | Yes | Yes |
| Masking | Yes | Yes | Yes |
| Routing | Yes | Yes | Yes |
| Schema transformation | Limited | Yes | Yes |
| Logs to metrics | Limited | No | Yes |
| Lookups | Limited | Yes | Yes |
| Data collection pull | Yes | No | No |
| UI-based management | No |
Yes | Yes |
| Central config | Deployment server |
Yes | Yes |
| Aggregations | No |
Yes | Yes |
Decision framework
Choose heavy forwarder when:
- You need data collection capabilities on the same infrastructure.
- Your transformation needs are basic (filtering, masking).
- You prefer configuration file-based management.
- You have existing heavy forwarder expertise.
Choose Edge Processor when:
- You need advanced transformation capabilities.
- You want centralized, UI-based configuration management.
- You're willing to invest in migration effort or it’s a new data source entirely.
- You want to leverage SPL2 capabilities.
Choose Ingest Processor when:
- You want advanced processing without infrastructure changes.
- You're on Splunk Cloud Victoria.
- You want to retain heavy forwarder parsing.
- You need quick time-to-value for advanced processing.
Third-Party solution considerations
If you are considering third-party solutions, compare specific use cases proposed by the vendor or desired by your organization and align them to heavy forwarder, Edge Processor, and Ingest Processor capabilities. Consider:
- Total cost of ownership including licensing, infrastructure, and operations
- Integration complexity with your existing Splunk environment
- Support and maintenance requirements
- Long-term strategic alignment with your data management goals
- Complete the migration discovery process.
- Use the evaluation questions in this guide to assess your environment.
- Document your findings and identify key considerations.
- Document your current architecture.
- Inventory all intermediate forwarder configurations.
- Map data flows and processing logic.
- Identify dependencies and integration points.
- Contact Your Splunk account team.
- Discuss your specific migration requirements.
- Understand licensing implications.
- Get connected with appropriate resources.
- Engage Splunk Services.
- Work with Splunk On-Demand Services or Professional Services for architectural guidance.
- Develop a detailed migration plan.
- Establish success criteria and validation approach.
- Plan for training.
- Identify team members who will manage Edge Processor.
- Plan for SPL2 training and enablement.
- Build internal expertise before migration.
Summary
Migrating from intermediate forwarders to Edge Processor can provide significant benefits including centralized configuration management, advanced transformation capabilities through SPL2, and improved processing efficiency. However, the migration requires careful planning and consideration of your specific environment.
Key takeaways:
- Assess thoroughly: Use the discovery questions to understand your current state and requirements
- Consider complexity: A wholesale replacement often introduces significant complexity; evaluate incremental approaches
- Understand parsing changes: Edge Processor does not parse events the same way heavy forwarders do; plan for remediation
- Leverage expertise: Engage Splunk services to help plan and complete your migration
- Consider alternatives: Ingest Processor might provide benefits without full migration effort
For questions about your specific migration scenario, please contact your Splunk account team or Splunk Support.
Additional resources
These additional Splunk resources might help you understand and implement this guidance:
