Following best practices for ingesting data from your AWS environment
Effectively collecting and utilizing information from your cloud environment is paramount for maintaining operational visibility, security, and performance. Amazon Web Services (AWS) offers a vast array of services, generating critical data that, when properly ingested and monitored, can provide invaluable insights into your organization's health and efficiency. However, navigating the myriad AWS services and architectural patterns for data ingestion can be complex.
This article serves as a guide, offering service-specific recommendations for ingesting data from your AWS environment into the Splunk platform. There are multiple methods for ingesting data from AWS. The Splunk Validated Architecture (SVA) for AWS discusses each of these methods in detail and helps you understand which method is best for your use case. The guidance for each of the services below builds upon the guidance in AWS SVA.
This article refers to the Data Inputs feature of the Splunk platform. Splunk renamed Data Manager to Data Inputs to better reflect our unified approach to data ingestion. While the name changed, all your existing configurations remain the same. In Splunk 10.4 and later, a navigation panel consolidates Data Inputs and related features into a single location. From there, you can switch between pages and manage all your data from one place.
AWS services
Amazon API Gateway
The recommended approach is to configure CloudWatch logging for your REST APIs in API Gateway, and then use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to Splunk HTTP Event Collector via Amazon Data Firehose.
If Data Inputs is not available to you, the next best option is to configure the Splunk Add-on for AWS to pull the logs from CloudWatch.
Click to see available resources
AWS Cost and Usage Reports (CUR)
The recommended approach is to configure the Splunk Add-on for AWS to pull your Cost and Usage reports.
Splunk GitHub: Configure Billing (Cost and Usage Report) inputs for the Splunk Add-on for AWS
Amazon CloudFront Access Logs
The recommended approach is to configure CloudWatch logging for CloudFront, and then use Data Inputs to deploy and monitor the infrastructure to push the access logs from CloudWatch to Splunk HTTP Event Collector.
If Data Inputs is not available to you, the next best option is to configure the Splunk Add-on for AWS to pull the access logs from CloudWatch.
AWS CloudHSM
Audit logging is automatically enabled in all AWS CloudHSM clusters. It cannot be disabled or turned off, and no settings can prevent AWS CloudHSM from exporting the logs to CloudWatch Logs. The recommended approach is to use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to Splunk HTTP Event Collector.
AWS CloudTrail
The recommended approach is to configure CloudTrail to send events to CloudWatch, and then use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to Splunk HTTP Event Collector.
If Data Inputs is not available to you, the next best option is to configure the Splunk Add-on for AWS to pull the logs from CloudWatch or S3.
AWS CloudTrail Lake
The recommended approach is to configure the Splunk Add-on for AWS to pull the data from your CloudTrail Lake.
Splunk GitHub: Configure CloudTrail Lake inputs for the Splunk Add-on for AWS
Amazon CloudWatch Logs
Amazon CloudWatch Metrics
The recommended approach is to configure the Splunk Add-on for AWS to pull your CloudWatch Metrics.
Splunk GitHub: Configure CloudWatch inputs for the Splunk Add-on for AWS
AWS Config Snapshots
The recommended approach is to configure the Splunk Add-on for AWS to pull your Config Snapshots.
Splunk GitHub: Configure Config inputs for the Splunk Add-on for AWS
AWS Config Rules
The recommended approach is to configure the Splunk Add-on for AWS to pull your Config Rule data.
Splunk GitHub: Configure Config Rules inputs for the Splunk Add-on for AWS
Amazon DocumentDB
The recommended approach is to configure monitoring of your DocumentDB using CloudWatch, and then use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to Splunk HTTP Event Collector.
If you use Amazon DocumentDB as a data source, you must enable audit logging both on your cluster and on Amazon DocumentDB in order to export logs to your CloudWatch log group for the accounts and regions that you select. See Monitoring Amazon DocumentDB with CloudWatch.
Amazon EKS
The recommended approach is to enable logging and monitoring in EKS, and then use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to Splunk HTTP Event Collector.
For additional Kubernetes logs and metrics, the recommended approach is to deploy the Splunk OpenTelemetry Collector.
AWS Elastic Load Balancer (ELB) Access Logs
The recommended approach is to enable access logs for your Application Load Balancers, and then use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to Splunk HTTP Event Collector.
Amazon GuardDuty
The recommended approach is to enable GuardDuty in your accounts, and then use Data Inputs to deploy and monitor the infrastructure to push the GuardDuty findings to Splunk HTTP Event Collector.
IAM Access Analyzer
The recommended approach is to enable IAM Access Analyzer in your accounts, and then use Data Inputs to deploy and monitor the infrastructure to push the data to Splunk HTTP Event Collector.
AWS IAM Credential Reports
The recommended approach is to use Data Inputs to deploy and monitor the infrastructure to push the IAM Credential Reports to the Splunk HTTP Event Collector.
Splunk Help: Onboard AWS in Data Inputs
Amazon Inspector (v2)
The recommended approach is to configure the Splunk Add-on for AWS to pull your Inspector v2 data.
Splunk GitHub: Configure Inspector v2 inputs for the Splunk Add-on for AWS
AWS Lambda
Lambda logs are sent to CloudWatch by default. The recommended approach is to use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to the Splunk HTTP Event Collector.
Metadata
The recommended approach is to use Data Inputs to deploy and monitor the infrastructure to push the Metadata to the Splunk HTTP Event Collector.
If Data Inputs is not available to you, the next best option is to configure the Splunk Add-on for AWS to pull the Metadata.
Amazon RDS
The recommended approach is to configure RDS to publish database logs to CloudWatch, and then use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to the Splunk HTTP Event Collector.
Amazon S3
The recommended approach is to use Data Inputs to deploy and monitor the infrastructure to pull data incrementally from S3 using SQS.
If Data Inputs is not available to you, the next best option is to configure the Splunk Add-on for AWS to pull data incrementally from S3 using SQS.
Amazon S3 Access Logs
The recommended approach is to configure accessing logging in S3, and then use Data Inputs to deploy and monitor the infrastructure to pull data incrementally from S3 using SQS.
AWS Security Hub
The recommended approach is to enable Security Hub in your accounts, and then use Data Inputs to deploy and monitor the infrastructure to push the Security Hub events to Splunk HTTP Event Collector.
Amazon Security Lake
The recommended approach is to configure the Splunk Add-on for AWS to pull your Security Lake data.
Splunk GitHub: Configure Security Lake inputs for the Splunk Add-on for AWS
AWS Transit Gateway Flow logs
The recommended approach is to configure the Splunk Add-on for AWS to incrementally pull your Transit Gateway Flow logs from S3 using SQS.
Splunk GitHub: Configure Transit Gateway Flow Logs inputs for the Splunk Add-on for AWS
Amazon VPC Flow logs
The recommended approach is to configure your VPC to publish Flow logs to CloudWatch, and then use Data Inputs to deploy and monitor the infrastructure to push the logs from CloudWatch to Splunk HTTP Event Collector.
If Data Inputs is not available to you, the next best option is to configure the Splunk Add-on for AWS to pull logs from CloudWatch.
Additional resources
These additional resources might help you understand and implement this guidance:
