Web application metrics visualization
You might want to chart key metrics related to application performance when doing the following:
- Splunk IT Service Intelligence
- Application server data
The application support engineers in your organization need proactive and predictive monitoring in their application environments to trend past activity and predict future application requests per minute. You want to set up that search for them, as well as a few others.
- Check that you have correctly installed and configured an application performance monitoring add-on, such as Splunk Add-on for New Relic or Splunk Add-on for AppDynamics.
- Run the following search:
tag=application tag=performance tag=apm app_title=* | timechart span=5min avg(thruput) BY host
- Update the value in
avg(thruput)to gather other key metrics and then run the search again. Some metrics you might want to track include:- response_time
- eum_thruput
- error_rate
- health
- availability
| Splunk Search | Explanation |
tag=application tag=performance tag=apm |
Search for events that are tagged as application, performance, or apm events. |
app_title=* |
Search for any app title. |
| timechart span=5min avg(thruput) BY host |
Graph the average throughput in 5 minute increments, grouped by host. |
For more granular results with scripted inputs, you can increase the frequency at which the input runs using the interval setting in inputs.conf. Running the input more frequently consumes more storage, and running it less frequently uses less, which can affect license consumption. The default interval is 60 seconds.
