Adopting ITSI capabilities strategically
Splunk IT Service Intelligence has many powerful features and capabilities that can improve your business operations. It can be tempting to deploy all of them at once for maximum impact. Doing so, however, can lead to more problems than it solves, causing scalability issues, skipped searches, and an overwhelmed and frustrated support staff.
This article is part of the Definitive Guide to Best Practices for IT Service Intelligence. ITSI administrators will benefit from adopting this practice as they work on Service Insights.
Solution
Take a careful and intentional approach to adopting Splunk IT Service Intelligence features. Here are four capabilities to be thoughtful about deploying:
  1. Service and KPI creation. Don't create too many services with meaningless KPIs. Use the Golden Signals to create an effective monitoring strategy that won't overwhelm your teams.
  2. Adaptive thresholding and time-based policies. Not every KPI needs these granular adjustments. Some services might be consistent, regardless of time of day or day of the week. Excess configuration in these cases adds unnecessary complexity.
  3. Anomaly detection. Not every KPI has a clear pattern, and some spikes are not actually anomalous. Trying to apply anomaly detection to every KPI can result in meaningless data, and create distractions and noise. Note that this feature was deprecated as of ITSI 4.20.0. It is no longer being updated and will be removed in a future version.
  4. Correlation searches and notable event aggregation policies (NEAPs). If you enable all correlation searches without considering whether they are applicable, you are going to create a lot of noise and make your data hard to decipher. Assess whether the included correlation searches are relevant to your services and use cases. Similarly, creating NEAPs where they are not needed also makes your data harder to use.
