Understanding the less exposed elements of ITSI
ITSI has a number of commands that can make your administrative life easier, but that’s not all. ITSI has ‘hidden’ fields that are not displayed in search results. These are very useful for many situations!
This article is part of the Definitive Guide to Best Practices for IT Service Intelligence. ITSI administrators will benefit from adopting this practice as they work on Service Insights.
Splunk IT Service Intelligence is not a standalone app; it is a collection of apps. When looking at all the configuration files, you might think that most functionality is found in /itsi/default. However, this is not the case. Some highly useful functions are available in /SA-ITOA.
Macros
There is a large collection of macros that come shipped with ITSI. Many of these macros are situational, used to troubleshoot or look into issues with a service or KPI. Others help you run investigations. In particular, you might find the following useful:
  • filter_maintenance_entities
  • filter_maintenance_services(1)
  • get_all_kpis_status
  • service_kpi_list
  • Any of the index macros, which you can adjust to help search performance
Here are sample investigation results that you might get from using the service_kpi_list macro. This macro provides a wealth of useful information regarding the KPIs in this environment.
Lookups
The SA-ITOA app also includes a number of built-in lookups.
If you are using the Splunk App for Lookup File Editing, SA-ITOA will be listed as ITOA Backend in the dropdown menu.
A few most useful lookups for getting information about your environment are:
  • itsi_backfill
  • itsi_services
  • itsi_refresh_queue
  • maintenance_calendar
  • itsi_entity_filter_rules
  • service_kpi_lookup
Here is an example of how you might use the itsi_entity_filter_rules lookup. The lookup shows the globally unique identifier (GUID) for entity rules, shown below in the _key field. This isn’t displayed by default but is really useful for lookups and | rest results.
When you add that _key field to your search, you pull up useful context that would otherwise be hidden, as shown in the search below.
