Monitoring an Amazon Web Services environment
To reduce the expenses of buying, owning, and maintaining physical data centers and servers, your organization has converted most of its infrastructure to cloud infrastructure on Amazon Web Services. This means you have whole new data types to secure and monitor. You need to learn the new services and the metrics that help you run your applications in the AWS cloud efficiently. You want to use Splunk software to manage all the different components of Amazon Web Services, including elastic cloud compute instances, elastic load balancer instances, virtual private clouds, and elastic block store volumes. You also plan to monitor user behavior on these systems.
There are multiple methods of getting AWS data into the Splunk platform. For more information on different approaches, see Getting AWS data into the Splunk platform.
  • Number of deprovisioned resources that are found to be idle
  • Cost savings from deprovisioning and optimization
  • Mean time to problem resolution
You may also want to look at the following processes in your organization that commonly impact success with this use case:
  • Capacity planning and resource optimization to keep operating expenses as low as possible
  • Provisioning and automation groups using orchestrators such as Kubernetes, Ansible, Puppet, and AWS CloudFormation
  • Security and compliance will consume and compliment data within this use case.
This use case is also included in the IT Essentials Work app, which provides more information about how to implement the use case successfully in your IT maturity journey. In addition, these Splunk resources might help you understand and implement this use case:
