Building a self-serve and scalable observability practice
In an ideal world, platform engineers would have a single internal developer platform to power all their developer teams, across multiple use cases and processes. Every developer team would be able to rely on that single extensible platform, allowing them to easily collaborate, and get what they need without compromise. This platform would also provide the central tools team visibility across data usage and role management for cost control.
In reality, most organizations deal with more than 10 different tools at a time (on average, 23 according to our recent State of Observability). Because many tools in the market are built for team-specific needs, each has its own standards and processes, which leads to developer teams operating in silos and longer war rooms. Not only that, but the lack of shared visibility doesn't allow platform engineers to monitor and control data usage
The result is bad for the engineering team, the business, and the customer.
  • Tool sprawl leads to analytics silos, which eventually hinders innovation pace and insights, as well as affects digital experiences
  • A cumbersome observability workflow also impacts the developer experience and creates toil
  • High costs and an inability to scale effectively
The solution is to build a self-service model with a mature observability platform. This leads to:
  • Higher productivity and increased velocity for better and more competitive digital experiences
  • Reduced effort and fewer errors
  • Subject matter expertise becomes more readily available with no need to rely on a central tool teams
  • More agile processes and workflows that allow people to accomplish what they need to on their own without waiting for someone else who might have a huge backlog
  • Templates with good defaults and a single, repeatable process or pattern, rather than starting from zero every time
  • Fewer bottlenecks, more insights from other teams, and better knowledge transfer of analytics
How Splunk software can help with this use case
The Splunk observability architecture, shown below, has a number of integrations and components that will help you establish observability as a service. The six sections in this article explain how to leverage them and what their benefits are.
OpenTelemetry
What is it?
OpenTelemetry (OTel) combines distributed tracing, metrics, and logging into a single set of system components and language-specific libraries. It is an industry-backed, extensible architecture that is completely vendor-agnostic and that makes robust, portable telemetry a built-in feature of cloud-native software. Specifically, the components include
  • Client libraries
    • Application instrumentation
    • Support for traces, metrics, events, and logs
    • Mobile and browser instrumentation
  • Collector
    • Receive, process, and export data
    • Default way to collect from instrumented apps
    • Can be deployed as an agent or service
  • Specification
    • API: Baggage, tracing, metrics
    • SDK: Tracing, metrics, resource, configuration
    • Data: Semantic conventions, protocol
What problems does it solve?
  • Cloud providers need to increase visibility to users because data volume is increasing and getting insights quickly is required.
  • Standardizes how observability telemetry is collected and transmitted across the industry.
  • Leverages the wider community for velocity, expertise, and innovation to manage the vast and ever changing needs for observability across digital systems.
  • End-users want a vendor-agnostic solution, while being able to choose the tools that are right for their business.
  • Everyone’s use-cases are different, which means that data portability and data flexibility are critical. Users need to be able to collect and analyze custom metrics.
  • OpenTelemetry is easy to set up, requiring to instrument only one time in the way that works best for you.
How to do it
This is the foundation for everything else you will do to create observability as a service. To get started adopting OpenTelemetry standards, go deep into a few workflows and service to understand the key questions and KPIs you need to answer within your organization and the metadata you need to support them. Implement a few first to be sure you get it right before moving on. Building out this maturity across a smaller set of key workflows will provide immediate value to your business, but also help ensure a smoother mass roll-out without propagating technical debt.
Metrics Pipeline Management
What is it?
Metrics pipeline management is a centralized ingestion data processing system that helps organizations tune and control data before being ingested. Pipelines can be configured to filter, aggregate, downsample, and archive data depending on data volume, cardinality, retention, granularity, and urgency needs. In Splunk Infrastructure Monitoring, metrics pipeline management allows admins flexibility and choice to control their metrics data at point of ingest, without re-instrumentation. With a UI or API approach out-of-the-box, admins can create aggregations on specific metrics identified. They also have the choice to filter for any unused data using dynamically defined policy rules.
From this refined set of aggregated custom metrics, SREs/observability experts continue working in their familiar workflows of detectors and charts but efficiently manage their volume of data without sacrificing service reliability. With this metrics aggregation and filtering capability, distributed teams maintain end-to-end visibility and extend on their Splunk data platform without having to compromise on insights.
  • Manage your metric cardinality centrally without the hassle of updating your collectors or ingest pipelines.
  • Control your costs by downsampling, aggregating, archiving, or filtering less-important data.
  • Improve performance by aggregating away high cardinality attributes.
How to do it
Use the guidance in Splunk Help to create rules that manage data in ways that reflect how you actually use the data. Keep in mind the following:
  • Real-time metrics:
    • Real-time alerting and query processing in single digit secs
    • Select a whole metric or only part of one
    • Low to high cardinality
  • Aggregated metrics
    • At a select time interval
  • Archived metrics:
    • Cold-storage. Pull into real time when necessary
    • No direct visualization or alerting
    • Good for high-noise, low value data
    • Ideal for occasional/infrequent access
  • Drop metrics completely
Role and User Management
What is it?
Pre-defined role-based access control is about reducing the order of privileges so that you don't have to worry about users breaking anything in a self-service model. You will manage users and roles across Splunk Cloud Platform and Splunk Observability Cloud through a single administrator experience.
  • One admin source of truth: Use Splunk Cloud Platform to assign out-of-the-box roles for Splunk Cloud Platform and Splunk Observability Cloud.
  • Additional layer of security: Easily make sure users in your organization have the right and consistent level of privilege and access with a consolidated experience across both Splunk Cloud Platform and Splunk Observability Cloud.
  • More extensibility with third-party identity provider compatibility: Extend your existing Splunk Cloud PlatformSAML integration to manage users and roles in Splunk Observability Cloud through a single integration with Splunk Observability Cloud.
How to do it
Use the guidance in Splunk Help to establish your Splunk platform to become the identity provider for Splunk Observability Cloud. The following roles are available after you set this up.
Role Privileges Persona
Admin Full admin privileges to manage the observability environment and other users Observability administrator
Power
Create and edit dashboards, detectors and other resources
Cannot create tokens, use integrations, access billing/usage
Developers, SREs
Usage Read-only privileges. Access to all data, including subscription usage and billing Billing, finance, MSPs
Read-only
Only read access to all resources like dashboards/detectors
Cannot view tokens
External teams, business owners
Observability As Code
What is it?
An observability-as-code approach includes the following elements:
  • Leveraging automation and orchestration for observability and monitoring
  • Ensuring validation, checks, and visibility around observability changes within the organization
  • Use a Terraform provider or APIs for configuration
  • Keeping a comments history of why things are the way are, an essential reference as people move on from roles or companies
  • Using access tokens
  • Sets the foundation for templating and reusable observability assets
  • Allows easy rollback to known working state when things go wrong
  • Simplifies ongoing maintenance and upkeep of observability assets
Focusing specifically on tokens,
  • Tokens are a safety net. If something coming through is too noisy and you want to stop the integration but not sever everyone's integration, tokens allow for that. You can allocate per team, per service, or per business unit.
  • You can measure and control usage by token. You can set tokens and quota limits on all billable metrics to visualize and control consumption by team or application.
  • Maintain granular, real-time visibility into all billable metrics and receive proactive alerts as you approach consumption limits.
How to do it
Use the guidance in Splunk Help to set up usage tokens.
Team Landing Page
What is it?
A team landing page in Splunk Observability Cloud lets you:
  • Highlight any active alerts specific to the team
  • View relevant detectors
  • Create a ‘go-to’ list of the team’s dashboards and mirrors
  • Favorite your most frequently viewed dashboards
  • Helps you find exactly what you need for your work instead of sifting through everything
  • Saves on duplicated content because everyone can leverage what one person has built
  • Prevents needing to update a bunch of copies of a dashboard when an integration changes
How to do it
Use the guidance in Splunk Help to create a team landing page and mirrored dashboards. Note the following about mirrored dashboards:
  • Mirrors of the same dashboard can be added to multiple dashboard groups (or even multiple times to one dashboard group)
  • Users can make changes to the dashboard, as long as they have write permissions for the dashboard
  • Changes made to the dashboard itself propagate to all of its mirrors
Data Usage Visibility
What is it?
Metrics usage analytics give you detailed visibility of your metrics usage in a self-serve reporting. Out-of-the box dashboards also provide insights into usage and license impact across the platform. These features allows you to
  • Understand which metrics, dimensions, and tokens generate the most metric time series
  • Determine how or if metric data is consumed in charts and detectors
  • Identify high cardinality dimensions contributing to metric usage
  • Optimize consumption by filtering or aggregating metrics
  • Surfaces noisy metrics that don't provide value
  • Helps you determine what rules you should establish around data ingestion
How to do it
Here is what you will want to keep track of:
  • Metrics usage analytics page: Located in Metrics > Usage Analytics
  • Splunk Infrastructure Monitoring: Located in-product at Settings > Subscription Usage
    • Monthly average usage and detailed hourly usage CSVs
  • Splunk Application Performance Monitoring: Located in-product at Settings > Subscription Usage
    • Monthly average usage + detailed per min usage CSVs
    • Usage Analyzer button to drill into “expensive” spans and traces
  • Splunk Real User Monitoring and Splunk Synthetic Monitoring: Located in-product at Dashboards > Org metrics > RUM or Synthetic Monitoring
    • RUM & Synthetics usage dashboards
Now that you have an idea of how to make your observability practice more scalable and self-service, watch the full .Conf25 Talk, Build a self-serve, scalable observability practice with Splunk. In the talk, you'll get more detail and practical tips for working through these six steps.
In addition, you might find these Splunk resources helpful:
