Location of remote workers
You might need to know where your remote workers are located when doing the following:
To succeed in implementing this use case, you need the following dependencies, resources, and information.
Your workforce is fully remote. To ensure network security, you want to report on where your remote workers are located.
To optimize the search shown below, you should specify a time range.
  1. Run the following search:
| tstats count(Authentication.user) FROM datamodel=Authentication WHERE (index=main OR index=firewall) BY Authentication.action Authentication.src
| rename Authentication.* AS *
| eval src = if(src=="216.113.183.230","142.252.17.31", if(src=="64.147.162.160","71.193.0.238",if(src=="216.129.122.242", "162.245.239.68", src)))
| iplocation src
| where len(Country)>0 AND len(City)>0
| geostats count BY action
| tstats count(Authentication.user) FROM datamodel=Authentication WHERE (index=main OR index=firewall) BY Authentication.action Authentication.src Search the main and firewall indexes for authentication actions and group the results by action and source. Set prestats to true so the results can be sent to a chart.
| rename Authentication.* AS *  Rename the field as shown for readability.
| eval src = if(src=="216.113.183.230","142.252.17.31", if(src=="64.147.162.160","71.193.0.238",if(src=="216.129.122.242", "162.245.239.68", src))) Convert the IP addresses for the matches shown; otherwise, return the source IP address from the dataset.
| iplocation src Extract location information from the IP addresses.
| where len(Country)>0 AND len(City)>0 Filter results to those where the values in the country and city fields are greater than one character.
| geostats count BY action Create a map that shows a count of authentication events.
This search produces a map of your users' locations and statistics about how many logins come in from each location. Correlate this information with the results of other searches to determine what is normal or anomalous activity on your network.
