Changes in DNS record type queries
You might need to review the types of DNS resource records being queried when doing the following:
  • Splunk Enterprise or Splunk Cloud Platform
  • DNS data
You want to monitor your network for changes in resource type behavior, which can be an early sign of data exfiltration.
To optimize the search shown below, you should specify an index and a time range. In addition, this sample search uses Stream DNS data. You can replace this source with any other DNS data used in your organization.
  1. Run the following search:
eventtype="stream_dns" message_type="Query"
| timechart span=1h count BY record_type
Search only Stream DNS events.
Search for queries.
Display a table that shows the types of DNS records accessed during one hour increments over the time span you set the search for.
Examine the results for changes in types of records being queried. Both A records and TXT records should be observed carefully as these are commonly used in command and control or exfiltration activity. If you have already identified a suspicious IP address, you can add it to the search to see if it is correlated with the changes in record types queried. You can also use the results to build a baseline or set thresholds for alerts.
