Requests to a large number of subdomains
You might want to monitor how many subdomains are requested per domain when doing the following:
You want to monitor how many subdomains are requested per domain to identify signs of data exfiltration or Domain Generation Algorithm domains.
Run the following search:
tag=dns message_type="Query"
| eval list="mozilla"
| `ut_parse_extended(query, list)`
| stats dc(ut_subdomain) AS HostsPerDomain BY ut_domain
| sort -HostsPerDomain
tag=dns
Search for fields with the "web" tag.
Search for queries.
| eval list="mozilla"
Search the Mozilla catalog for top level domains.
This eval function is required for the next line in the search (ut_parse_extended) to work.
Parse the queries based on the Mozilla top level domain list.
The punctuation surrounding a Splunk macro is always a back tick (`), not a single quote (').
| stats dc(ut_subdomain) as HostsPerDomain by ut_domain
Return the results in a table—grouped by the ut_domain field—that includes a count of the number of distinct subdomains for each domain seen.
Sort the results with the domain with the highest number of subdomains appearing first.
The search results include all domains. Since you probably aren't concerned about queries to subdomains of microsoft.com or other known good sites, you can use lookups to remove noise.
