Signs of beaconing activity
Beaconing activity is when a compromised host ‘checks in’ with the command infrastructure, potentially waiting for new instructions or updates to the malicious software itself.
You might want to use Splunk for beacon detection to help with the following use cases:
  • Splunk Enterprise or Splunk Cloud Platform
  • DNS data
You want to monitor your network to see whether any hosts are beaconing—or checking in with—malicious command and control infrastructure.
To optimize the search shown below, you should specify an index and a time range. In addition, this sample search uses Stream DNS data. You can replace this source with any other DNS data used in your organization.
Run the following search:
eventtype="stream_dns" message_type="Query"
| fields _time, query
| streamstats current=f last(_time) AS last_time BY query
| eval gap=last_time - _time
| stats count avg(gap) AS AverageBeaconTime var(gap) AS VarianceBeaconTime BY query
| eval AverageBeaconTime=round(AverageBeaconTime,3), VarianceBeaconTime=round(VarianceBeaconTime,3)
| sort -count
| where VarianceBeaconTime < 60 AND count > 2 AND AverageBeaconTime>1.000
| table query VarianceBeaconTime  count AverageBeaconTime
Search only Stream DNS events.
Search for queries.
| fields _time, query
Keep only the time and the query field to speed up the search.
Stream the last time each query was seen for all preceding events (excluding the current event) and output as last_time, grouped by query.
Calculate the gap between the last_time each query was seen and the current event.
Calculate count for each query. For each query, also calculate the average gap and display it in an AverageBeaconTime column, and calculate the gap variance and display it in a VarianceBeaconTime column.
Round the AverageBeaconTime and VarianceBeaconTime results to three decimal places.
| sort -count
Sort the results with the query with the highest occurrence appearing first.
Filter results to display only results with a low variance relative to the other parameters. You can adjust these numbers according to baselines for your organization.
Low time variance in time in queries may indicate that hosts are contacting command and control infrastructure on a predetermined time slot. You might want to investigate activity on those hosts more closely. You can also add the src field to the | fields line of this search:
| fields _time, src, query
and a distinct count to the | stats line
| stats count dc(src) AS NumHosts avg(gap) AS AverageBeaconTime var(gap) AS VarianceBeaconTime BY query
to see the number of distinct hosts engaging in the same beaconing behavior.
