Percentage of total bytes out from a source to a single destination
You might need to compare the total bytes going out from a source IP address to those going to each destination IP address when doing the following:
You want to create an accurate picture of outbound traffic from your overall network to different destination IP address so that you can monitor for anomalous behavior.
To optimize the search shown below, you should specify an index and a time range. In addition, this sample search uses Fortinet FortiGate data. You can replace this source with any other firewall data used in your organization.
  1. Run the following search:
sourcetype=fgt_traffic src=<IP address sending the request> NOT (dest=<Internal IP address> OR dest=<DNS>)
| eventstats sum(bytes_out) AS total_bytes_out BY src
| eval percent_bytes_out = bytes_out/total_bytes_out * 100
| table src dest bytes_in bytes_out total_bytes_out percent_bytes_out
| where percent_bytes_out > 60
| sort - percent_bytes_out dest
Search only Fortinet FortiGate network traffic data.
Search data coming from this IP address.
If you want to search all IP addresses in a netblock, use a wildcard search. For example, src=192.168.255.*
Exclude internal and DNS destination IP addresses.
Logs vary in the information they contain. Not all logs have hostnames or IP addresses. Sometimes the dest field will have a hostname in it but sometimes it will have an IP address. Parentheses and OR statements will broaden your search so you don’t miss anything.
Example:
(dest=”192.0.2.0” OR dest_ip=”192.0.2.0”)
Example:
(dest=”192.0.2.0” OR dest=”example.com”)
| eventstats sum(bytes_out) AS total_bytes_out BYsrc
Calculate the total volume of bytes_out to any destination for each source and display in a total_bytes_out column.
For each source-destination pair, calculate the bytes_out as a percentage of the overall bytes_out for the source IP address.
Display only results where the percentage of traffic of outbound traffic to a single IP address is greater than 60 percent of the total traffic for the source IP address.
Sort the results by the largest percent_bytes_out values per destination IP address.
The results show the destination IP addresses that receive the most traffic and what source IPs that traffic comes from. Visibility into how many of your source IP addresses communicate with the same destination IP addresses can help you establish whitelists. You can also use this information to create network traffic baselines and thresholds to trigger security alerts.
