Monitoring for network traffic volume outliers
You work for a small company and your manager wants you to put together a report on typical network usage among your users. Specifically, your manager is interested in which external websites network users most often communicate with.
You need to establish usage baselines and monitor them for anomalous behavior. You can use the stats command to perform a number of simple statistical calculations that give you a picture of traffic flows from your network hosts to external IP addresses.
Network traffic data
You can run many searches with Splunk software to establish baselines and set alerts. Depending on what information you have available, you might find it useful to identify some or all of the following:
As you establish baselines, you might find source IP addresses that you want to investigate immediately. You can run the following investigations based off results from the monitoring activities in this use case:
To maximize their benefit, the articles linked in the previous section likely need to tie into existing processes at your organization or become new standard processes. These processes commonly impact success with this use case:
  • Understanding cyclical usage patterns
  • Understanding network management policies
  • Creating inventories of physical and virtual network devices
  • Creating network diagrams
  • Adhering to frameworks, such as the IT Infrastructure Library
Measuring impact and benefit is critical to assessing the value of security operations. The following are example metrics that can be useful to monitor when implementing this use case:
  • Identification of risk factors: The number of anomalies you identified that were positive security risks
These additional resources might help you with this use case:
