Volume of traffic between source-destination pairs
Your organization has been experiencing sluggish performance on its network. You want to identify problematic destination IP addresses and establish alerts for when network usage becomes too high so you can clean up bandwidth bottlenecks.
Procedure
This sample search uses Fortinet FortiGate data. You can replace this source with any other firewall data used in your organization.
Run the following search. You can optimize it by specifying an index and adjusting the time range.
sourcetype=fgt_traffic src=<IP address sending the request> NOT (dest=<Internal IP address> OR dest=<DNS>)
| stats sum(bytes_in) sum(bytes_out) BY src dest
| table src dest bytes_in bytes_out
| sort – bytes_out
Search only Fortinet FortiGate network traffic data.
Search data coming from this IP address.
If you want to search all IP addresses in a netblock, use a wildcard search. For example, src=192.168.255.0/24
Exclude internal and DNS destination IP addresses.
Logs vary in the information they contain. Not all logs have host names or IP addresses. Sometimes the dest field will have a hostname in it but sometimes it will have an IP address. Parentheses and OR statements will broaden your search so you don’t miss anything.
Example:
(dest=”192.0.2.0” OR dest_ip=”192.0.2.0”)
Example:
(dest=”192.0.2.0” OR dest=”example.com”)
Sum the total volume of bytes_out and the total volume of bytes in for each source-destination pair.
| sort – bytes_out
Sort the results by the source-destination pair with the largest volume of bytes out first.
Use the results to establish baselines or examine the results for outliers. Change the sort order as needed to look at the top inbound byte volumes or the lowest byte counts, if that is appropriate for your use case. Set an alert for when the number of source-destination connections exceeds a certain threshold. You can also monitor for potential concerns, such as many hosts from the same subnet all communicating to the same destination IP, with identical byte counts, both in and out.
You might also be interested in other processes associated with the Monitoring for network traffic outliers use case.
