Web shell present in web traffic events
Your company uses SolarWinds Orion business software, which is vulnerable to the Supernova in-memory web shell attack. Because it runs in-memory, you know that detection and forensic analysis post-breach are difficult. You want to search your web data to see if the web shell exists in memory. This is done by looking for calls to the known to be implemented and called in the trojanized versions of the API. Finding these in your web logs would be an indicator of compromise.
Required data
Option 1 - Normalized data
  1. Ensure that your deployment is ingesting endpoint logs from your various systems. You should also ensure you are ingesting normalized data, populating the Web data model in the Common Information Model (CIM). For information on installing and using the CIM, see the Common Information Model documentation.
  2. Run the following search. You can optimize it by specifying an index and adjusting the time range.
    | tstats count FROM datamodel=Web.Web WHERE
        web.url=*logoimagehandler.ashx*codes* OR
        Web.url=*logoimagehandler.ashx*clazz* OR
        Web.url=*logoimagehandler.ashx*method* OR
        Web.url=*logoimagehandler.ashx*args* groupby Web.src Web.dest Web.url
        Web.vendor_product Web.user Web.http_user_agent _time span=1s
Query the Web data model for the given URLs and group the results by the fields shown.
Option 2 - Stream data
This sample search uses Stream HTTP data. You can replace this source with Zeek or any other data set that contains information around http and URI filenames and parameters used in your organization.
  1. Ensure that you have installed and configured the Splunk App for Stream.
    sourcetype=stream:http Dest_ip =< IP of SolarWinds system you are investigating>
        (url=*logoimagehandler.ashx*codes* OR Web.url=*logoimagehandler.ashx*clazz*
        OR Web.url=*logoimagehandler.ashx*method* OR
        Web.url=*logoimagehandler.ashx*args*)
    | table _time src_ip src_port dest_ip dest_port url transport status
sourcetype=stream:http  Search only Stream HTTP data.
Search the system you want to investigate for this inbound traffic.
Search for these URLs being requested from the web client.
| table _time src_ip src_port dest_ip dest_port url transport status Display the results in a table with columns in the order shown.
If these URLs found in the web server logs are called successfully, you can assume that the web server is infected with the webshell. Investigate further and then run your incident response plan to clean the web server of the malware.
Finally, you might be interested in other processes associated with the Detecting Supernova web shell malware use case.
