Maintaining *nix systems with the Splunk platform
In your organization, you have lots of *nix systems running critical applications or services. You need to monitor these systems to ensure the health of the associated apps and services, such as basic configuration, system diagnostics, file systems, and packages. You need to log and watch all these components, and ensure that appropriate technical staff are notified as quickly as possible if problems arise. With all these different concerns, you need Splunk searches that you can save and easily run on a schedule or as needed to keep your users up and running.
You can use Splunk software to manage patches and updates to ensure all connected systems and related processes are running after the patch or update is complete. You can also use Splunk software for a number of other maintenance tasks, such as watching out for connectivity issues.
Technologies:
Data:
  • Running regular backups
  • Maintaining tooling for software provisioning
  • Maintaining tooling for configuration management
  • Site reliability engineering processes
  • Mean time to resolution
  • Mean time to root cause
  • Reduction in defects
